Manual toolchanger does not show up
24 Feb 2014 19:07 #44119
by kostas
Manual toolchanger does not show up was created by kostas
I'm having a problem on a configuration that I made for a friend. Linuxcnc loads correctly, the first manual toolchanger window shows when hal_manualtoolchange loads and everything works correctly, except that the manual toolchange window does not show when a tool must be changed. When this happens Axis does not execute MDI commands until we power off and on Axis (F2).
Any thoughts of what might be the cause?
24 Feb 2014 20:13 #44122
by ArcEye
Replied by ArcEye on topic Manual toolchanger does not show up
Hi
You will need to post the config, simply wild guessing otherwise
24 Feb 2014 21:06 #44124
by kostas
Replied by kostas on topic Manual toolchanger does not show up
Sure. Here it is.
24 Feb 2014 21:08 #44125
by kostas
Forum doesn't support .tcl files as attachments?
Here is the .tcl as .txt
24 Feb 2014 21:52 #44127
by ArcEye
Hi
I think you are missing
See if that solves your problem
The following user(s) said Thank You: kostas
24 Feb 2014 23:45 #44131
by kostas
Yes, this works! Thanks!
Time to create page: 0.231 seconds
