Enable/disable run button
08 Mar 2014 18:58 #44564
by keyson
Enable/disable run button was created by keyson
Hi all, and thank's for all effort to make Linuxcnc better and better.
As the topic say, I would like to disable and enable the run button in Axis on an external signal.
Searched the forums and studied manuals but have not come up with an answer.
I have retrofitted two Denford triac vmc (mod 94) for educational purpose.
They have a 'door' (hatch) that have a sensor (guard contact) that i would like to run trough
a and gate, to make it impossible to run the program if the door is open.
But the jogging would run, so hook it to the enable or e-stop is not an option.
Regards
Kjell
Regards
Kjell
08 Mar 2014 20:04 - 08 Mar 2014 21:08 #44565
by ArcEye
Replied by ArcEye on topic Enable/disable run button
Hi
You can achieve this quite simply by a short hack of Axis
After line 2071 in the master (search for def task_run(*event): )
insert
ie
Then at line 3243 in the master ( search for comp.newpin("notifications-clear-error",hal.HAL_BIT,hal.HAL_IN))
insert
comp.newpin("run-disable",hal.HAL_BIT, hal.HAL_IN)
ie
You will now have a pin called axisui.run-disable
If that is set to TRUE (1) it will not be possible to run a program as the function will return
insert
if comp['run-disable'] : return
ie
if comp['run-disable'] : return ## inserted line
if run_warn(): return
global program_start_line, program_start_line_last
program_start_line_last = program_start_line;
ensure_mode(linuxcnc.MODE_AUTO)
c.auto(linuxcnc.AUTO_RUN, program_start_line)
program_start_line = 0
t.tag_remove("ignored", "0.0", "end")
o.set_highlight_line(None)
insert
ie
if hal_present == 1 :
comp = hal.component("axisui")
comp.newpin("jog.x", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.y", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.z", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.a", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.b", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.c", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.u", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.v", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.w", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.increment", hal.HAL_FLOAT, hal.HAL_OUT)
comp.newpin("notifications-clear",hal.HAL_BIT,hal.HAL_IN)
comp.newpin("notifications-clear-info",hal.HAL_BIT,hal.HAL_IN)
comp.newpin("run-disable",hal.HAL_BIT, hal.HAL_IN) ## inserted line
vars.has_ladder.set(hal.component_exists('classicladder_rt'))
Last edit: 08 Mar 2014 21:08 by ArcEye. Reason: make [ ] brackets visible
08 Mar 2014 20:18 #44566
by keyson
Replied by keyson on topic Enable/disable run button
That was fast ArcEye,
Nice fix.
Thank's
/Kjell
Nice fix.
Thank's
/Kjell
Time to create page: 0.145 seconds
