Sending G-codes to AXIS via serial line
19 Jun 2014 20:10 - 19 Jun 2014 20:48 #48122
by jbubik
Sending G-codes to AXIS via serial line was created by jbubik
Greetings,
a friend of mine wants to make a manual control for his machine. He decided to use some knobs and buttons hooked up to a microprocessor (8051 or something). That thing would produce G-codes for small movements. I was looking for a way to feed the G-codes from external box to a PC with linuxcnc/AXIS. Here is my solution:
There is a way to send G-codes to a running instance of AXIS from command line (axis-remote -m "G0 ...")
I made a similar program that reads the serial line in a loop and sends each line of text to AXIS.
1.Create the script - paste the text from below2. Make it executable3. Start linuxcnc/AXIS
4. Start the utility
The G-codes are read from specified device (/dev/ttyS0). Speed of the serial port is set-up to (115200). G-codes must be separated by a newline character (\n).
What I don't know is how to start this utility automatically after AXIS initialization. I do it manually. Maybe one could modify the launcher icon...
I don't mind this utility would be included in official packages.
Jan
The script:
sudo editor /usr/bin/axis-serial-control
sudo chmod a+x /usr/bin/axis-serial-control
axis-serial-control /dev/ttyS0 115200
Jan
The script:
#!/usr/bin/python
# This is a component of AXIS, a front-end for LinuxCNC
# Copyright 2006 Jeff Epler <jepler@unpythonic.net> and
# Chris Radek <chris@timeguy.com>
# axis-serial-control by Jan Bubik <bubik@acvyskov.cz>
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
axis-serial-control: send G-codes from serial line into a running AXIS GUI
Usage: axis-serial-control device speed
Example: axis-serial-control /dev/ttyS0 115200"""
import sys, Tkinter, serial, time
def usage(exitval=0):
print __doc__
raise SystemExit, exitval
if len(sys.argv) != 3:
usage(99)
# Serial Stuff, change the serial port address by changing /dev/ttyS0
ser = serial.Serial(sys.argv[1], sys.argv[2], bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=0, rtscts=0)
t = Tkinter.Tk(); t.wm_withdraw()
msg = ""
try:
#Main Loop
while 1:
time.sleep(0.2)
cmd = ser.readline()
if cmd.strip() != '':
msg = t.tk.call("send", "axis", ("remote","send_mdi_command", cmd))
except Tkinter.TclError,detail:
raise SystemExit,detail
if msg:
raise SystemExit,msg
# vim:sw=4:sts=4:et:
Last edit: 19 Jun 2014 20:48 by jbubik.
19 Jun 2014 20:56 #48124
by jbubik
Replied by jbubik on topic Sending G-codes to AXIS via serial line
Trying to attach the file again...
21 Jun 2014 15:25 #48158
by pippin88
Replied by pippin88 on topic Sending G-codes to AXIS via serial line
Does he just want the functionality of a manual pulse generator (MPG)?
25 Jun 2014 19:28 #48241
by jbubik
Well, MPG seems to be the way to go. With the USB/HID from generichid.sourceforge.net/ it should be OK. Thank you.
Still sending G-codes via serial interface might be useful for someone.
Jan
Jan
Time to create page: 0.133 seconds
