AXIS to hal
- grzesiekzxr
13 Nov 2014 05:51 - 13 Nov 2014 05:59 #53050
by grzesiekzxr
AXIS to hal was created by grzesiekzxr
Hey guys,
I'm using Axis 2.5.2. and trying smething like: c.set _digital_output(18,0),
I putting it into axis.py number line 1995-2000.
My general problem is ,when I brake/stop not finished program ,some pins are stil active .
But mention solution not working for me .
Any idea?
Any idea?
Last edit: 13 Nov 2014 05:59 by grzesiekzxr.
13 Nov 2014 17:31 - 13 Nov 2014 17:32 #53061
by ArcEye
Replied by ArcEye on topic AXIS to hal
Hi
You will need to explain what you are doing.
The code at the lines you give appears to be the starting of a program and you are using the python interface to set EMC_MOTION_SET_DOUT
What is your program using it for? There may be a much simpler way of doing it than hacking Axis.
def task_run(*event):
if run_warn(): return
global program_start_line, program_start_line_last
program_start_line_last = program_start_line;
ensure_mode(linuxcnc.MODE_AUTO)
c.auto(linuxcnc.AUTO_RUN, program_start_line)
program_start_line = 0
t.tag_remove("ignored", "0.0", "end")
o.set_highlight_line(None)
Last edit: 13 Nov 2014 17:32 by ArcEye.
- grzesiekzxr
14 Nov 2014 05:07 - 14 Nov 2014 05:16 #53071
by grzesiekzxr
Replied by grzesiekzxr on topic AXIS to hal
HI my axis.py line are
nr.1995 def task_stop(*event):
if s.task_mode == linuxcnc.MODE_AUTO and vars.running_line.get() != 0:
o.set_highlight_line(vars.running_line.get())
c.abort()
c.wait_complete()
nr. 2000 c.set_digital_output(18,0)
/home/grzegorz/realtime/master/src/emc/usr_intf/axis/scr
I'm using Eagle to create hal .
Example when I run my program there is much M64 p....and if program don't finish M65p...is absent ,thereby some pins are still active.
Thanks ,
Regards.
c.abort()
c.wait_complete()
Thanks ,
Regards.
Last edit: 14 Nov 2014 05:16 by grzesiekzxr. Reason: mistake
- grzesiekzxr
26 Nov 2014 05:28 #53417
by grzesiekzxr
Hallo,
Maybe there is another solution ?
I think that not only me interrupt a program, if something does not play in gcode .
How do you deal with such a problem?
regards.
regards.
Time to create page: 0.123 seconds
