manual tool change
15 Jan 2015 01:21 - 15 Jan 2015 01:23 #55010
by agris
manual tool change was created by agris
Hi guys,
LinuxCNC 2.5.3
I used a script (described here) to use manual toolchange. I.e., when M6 T1 is issued, program stops, allowing me to touch off manually, and then hitting Continue in dialog box run a program further. That seem working well.
But randomly, on same program, the M6 T* is just ignored. Program doesn't stop, no dialog box appear. LinuxCNC silently changes a tool number (you may see it in bottom of Axis screen), and run a program further.
Just an example:
G0 x100
M6 T1 <-- this line may be ignored, if I already have T1 installed, that's ok. Tool number is being changed here to 1
M3 S2000
G0 x200
M6 T2 <-- this line sometimes is ignored for no reason, even currently installed tool is 1.
M3 S2000
G0 x100
There's a hal_manualtoolchange file in attach.
Did anyone see such behavior?
Thanks in advance!
LinuxCNC 2.5.3
Just an example:
G0 x100
M3 S2000
G0 x200
M3 S2000
G0 x100
Thanks in advance!
Last edit: 15 Jan 2015 01:23 by agris.
Time to create page: 0.323 seconds
