Gcode placement
- allenwg2005
- Topic Author
- Thank you received: 4
11 Feb 2015 10:22 #55883
by allenwg2005
Gcode placement was created by allenwg2005
I'm confused!
I am useing 8.4 (Hardy), Axis interface, on a gantry router.
I made up a jig to hold my material and have CAD work and Gcode for same.
I'm running parts one after another with great results, I get to the last part (naturaly) and load-up material and start things up.
The machine dumped the profile on the material -.300 in Y for some reason.
Shut it down, restarted and it's fine.
What would cause this to happen?
11 Feb 2015 19:57 #55889
by ArcEye
Replied by ArcEye on topic Gcode placement
Hi
There are all sorts of things, from missed steps, co-ordinate system change, to tool compensation having been taken off or put on when not expected.
(M2 or M30 will do both of the latter)
If the distance is absolutely consistent and exact, would suspect it is something in the settings or lack thereof.
Without a lot more info, just guessing
The following user(s) said Thank You: allenwg2005
Time to create page: 0.240 seconds
