Default demo program
24 May 2015 09:21 #58963
by krlynn
Default demo program was created by krlynn
Is there any way to edit or replace the default program that opens with Axis (in my case axis-lathe.ngc)?
24 May 2015 16:16 #58964
by ArcEye
Lots, easiest probably just to replace or edit /usr/share/axis/images/axis-lathe.ngc
Replied by ArcEye on topic Default demo program
The following user(s) said Thank You: krlynn
24 May 2015 19:40 #58967
by krlynn
Replied by krlynn on topic Default demo program
Thanks. I've tried. Can't edit it, can't move it, can't delete it. Can't change permissions.
Don't doubt there is a simple way, but I haven't been able to figure it out.
24 May 2015 20:09 #58968
by krlynn
OK, Owner was/is root. I figured out how to create a password for root with sudo.
Thanks again.
Thanks again.
24 May 2015 20:12 #58969
by ArcEye
From a terminal
$sudo gedit /usr/share/axis/images/axis-lathe.ngc
will allow you to edit it
$sudo <whateveryourfilemanageriscalled>
will let you delete, move change permissions etc
24 May 2015 21:09 #58970
by krlynn
Thanks. I got it done taking a slightly different route. Created a password for root, then logged into root via "Other". That allowed me to edit the file.
25 May 2015 02:35 #58973
Replied by cmorley on topic Default demo program
Not sure if I am missing what you are asking but if you want AXIS to auto load a particular program,
set this line in the INI file under [DISPLAY}
OPEN_FILE = /full/path/to/filename.ngc
Chris M
www.linuxcnc.org/docs/2.6/html/config/in...#sub:DISPLAY-section
Chris M
25 May 2015 19:38 #59008
by krlynn
Thanks, Chris. I didn't so much want it to load a particular program as NOT to load the default program as written (i.e., without a stop at the start).
It's fixed now, but I'm interested in your suggestion anyhow. I started out by looking everywhere I could think of to look for an instruction specifying the default file so I could change that, since I couldn't figure out how to edit the existing default file. Didn't find it anywhere, and still haven't. Probably overlooking it, but FWIW I just checked again and didn't see anything like OPEN_FILE = /full/path/to/filename.ngc in the ini or hal files. I'd still like to know where that instruction sits.
26 May 2015 01:51 #59026
says:
OPEN_FILE = /full/path/to/file.ngc - The file to show in the preview plot when AXIS starts. Use a blank string "" and no file will be loaded at start up.
Chris M
says:
Chris M
Time to create page: 0.315 seconds
