Lathe tool display error
18 Jun 2015 01:13 - 18 Jun 2015 03:46 #59918
by Simmsey
Lathe tool display error was created by Simmsey
I have a problem with lathe tools not being displayed correctly.
The issue only occurs when I use .axisrc file entries to flip the X axis screen display to match a back tool machine I have. The axisrc entries I have used are per:
wiki.linuxcnc.org/cgi-bin/wiki.pl?BackToolLathe
Attached some screen shots of tool display error. Just a few pixels shown - these pixels displayed come and go as the screen is panned and zoomed.
Also attached is a correct normal display - only difference is removal of .axisrc file.
Is this a known bug? Is there an error in the .axisrc screen flipping I am using?
Has anyone else managed to get this to display correctly?
I have tried playing with the tool display values in the tool table e.g. front and back angles without success. Interestingly a negative tool tip dia setting did display more than just dots but not correctly - screenshot also attached.
Simmsey
Linuxcnc/Axis 2.6.8
Simmsey
Linuxcnc/Axis 2.6.8
Last edit: 18 Jun 2015 03:46 by Simmsey.
18 Jun 2015 04:04 #59923
by emcPT
Replied by emcPT on topic Lathe tool display error
Hello.
That is a known bug.
Time to create page: 0.101 seconds
