Automatic pause when spindle is started
15 Feb 2016 22:12 #70194
Replied by cmorley on topic Automatic pause when spindle is started
motion.feed-inhibit or
motion.spindle-at-speed
might be more appropriate (and safer) then pausing the program.
feed-inhibit (which i believe works on rapids as well) would allow no movement (unless in the middle of a thread pass)
spindle-at-speed - Motion will pause until this pin is TRUE, under the following conditions: before the first feed move after each spindle start or speed change; before the start of every chain of spindle-synchronized moves; and if in CSS mode, at every rapid to feed transition. This input can be used to ensure that the spindle is up to speed before starting a cut, or that a lathe spindle in CSS mode has slowed down after a large to small facing pass before starting the next pass at the large diameter. Many VFDs have an at speed output. Otherwise, it is easy to generate this signal with the HAL near component, by comparing requested and actual spindle speeds.
These pins are realtime, HALUI is not
Chris M
Chris M
The following user(s) said Thank You: Rubenv
15 Feb 2016 22:19 #70195
feed-inhibit works on feed, rapids and jogging
16 Feb 2016 19:24 #70247
by Rubenv
Replied by Rubenv on topic Automatic pause when spindle is started
Thanks Chris
You don't perhaps have a sample. I am still finding my way!
Ruben
Ruben
- Thank you received: 1369
16 Feb 2016 21:26 #70253
Replied by Todd Zuercher on topic Automatic pause when spindle is started
The RS485 solution would not use any parallel port io, it would use a serial port connection (ordinary com port or USB port via an rs485 adapter in both cases). Yes you can usually access all of the drives commands, readouts, and settings. But it is not necessarily easy to set up, and can take a fair bit of programming and configuration to accomplish especially if there isn't a driver specifically set up for your VFD.
If all you need is to turn on/off the drive, and wait for it to spin up. it will be far simpler just to use your parallel port io (if you don't have enough pins consider adding a second port with a pci card (you can have up to 3). If you don't want to do that, it might be easier just to insert a G4 P? pause after your spindle start command in your G-code.
17 Feb 2016 12:35 #70284
by Rubenv
Thanks Todd, will add that to a bucket for when I understand much more
Can anyone help me with a sample config for motion.feed-inhibit?
Would much appreciate it!
Ruben
Ruben
17 Feb 2016 19:32 #70303
by Rubenv
Guys
This is what I have, but i don't get the motion enabled again. it works fine to stop the motion for 5 sec, but it stays that way...
i can't link the pin a second time..
loadrt timedelay count=1
addf timedelay.0 servo-thread
setp timedelay.0.on-delay 5
setp timedelay.0.off-delay 5
net spindle-on <=> motion.feed-inhibit
net spindle-on => timedelay.0.in
net spindle-ready <= timedelay.0.out
net spindle-ready => motion.feed-inhibit ---> here I get the error
please help?
Ruben
please help?
Ruben
17 Feb 2016 20:11 - 17 Feb 2016 20:14 #70307
You cant use the same pin twice. Also I think your logic is flawed. You are also going to need an xor2 or something to make it all work.
Something likeI think this is also going to pause the machine when you turn off the spindle. If that is what you want, if not just change the timedelay.0.off-delay to 0.
Something like
loadrt xor2 count=1
addf xor2.0 servo-thread
net spindle-on => xor2.0.in0
net spindle-timer <= timedelay.0.out
net spindle-timer => xor2.0.in1
net spindle-ready <= xor2.0.out => motion.feed-inhibit
Last edit: 17 Feb 2016 20:14 by Todd Zuercher.
18 Feb 2016 02:18 - 18 Feb 2016 02:20 #70331
blank
Last edit: 18 Feb 2016 02:20 by cmorley. Reason: logic was flawed :)
18 Feb 2016 06:08 #70333
by Rubenv
Thanks Todd,
I was thinking of adding another function. I have really searched but there is not allot available on this subject.
I will test tonight!
Ruben
Ruben
18 Feb 2016 12:05 #70338
by BigJohnT
I just put a M0 after my M3 and when my spindle is set I press the run button.
JT
Replied by BigJohnT on topic Automatic pause when spindle is started
Hello,
It takes some time for my spindle to reach the desire rotation speed. So I have to manually ad a G4 P10 on every file that is generated from my CAM tool.
Is there a way to tell LinuxCNC to always wait for X secodns when the spindle is started before starting to move ?
Than you !
JT
Time to create page: 0.328 seconds
