got oval instead of circle cambam->linuxcnc
- altihu
27 Aug 2015 23:08 #61842
by altihu
got oval instead of circle cambam->linuxcnc was created by altihu
Hi
any suggestions to solve the problem shown in the screenshot ? linuxcnc does not follow the line of the circle, it generates a oval out of the circle.
you see the g-code for the circle between line 14 and 18.
linuxcnc 2.6.9
cambam plus 0.9
cambam settings (linuxCNC postproc.):
arc center incemental G91.1
arc center absolute G90.1
arc center mode standard
number format 0.0####
arrow to line tolerance 0.01
any ideas for config settings (.hal, .ini ) to check (cambam or linuxcnc) ?
tnx
linuxcnc 2.6.9
cambam plus 0.9
tnx
- cncbasher
- Thank you received: 288
27 Aug 2015 23:12 - 28 Aug 2015 01:52 #61843
by cncbasher
Replied by cncbasher on topic got oval instead of circle cambam->linuxcnc
if your getting an oval instead of a circle , then you have mechanical axis issues
if this is a stepper machine, they you could be missing steps
or possibly your running the axis at velocity that it cannot handle
could even be your power supply is struggling , but mechanical issues are the main problem,
post your complete gcode file as an attachment
i'll take a guess this is a gantry machine , and theirs mechanical flex in the gantry and flexing front to back
Last edit: 28 Aug 2015 01:52 by cncbasher.
- ArcEye
- Thank you received: 758
27 Aug 2015 23:19 #61844
by ArcEye
Replied by ArcEye on topic got oval instead of circle cambam->linuxcnc
Machine flex is a common source.
Cutting a circle tests the rigidity through 360 degrees.
- Delron
28 Aug 2015 05:48 #61847
by Delron
Replied by Delron on topic got oval instead of circle cambam->linuxcnc
Think it's a settings issue. The plot would not follow mechanical problems.
Looks like the trajectory planner is responsible. I might be wrong, but if your acceleration setting is low, then this can happen. What happens if you lower the feed rate?
- Thank you received: 5294
28 Aug 2015 08:05 - 28 Aug 2015 08:09 #61848
Replied by PCW on topic got oval instead of circle cambam->linuxcnc
I would check your G64 settings.
If not setup by your CAM programs preamble, the default is plain G64 which means
keep up feed rate regardless of path deviation...
linuxcnc.org/docs/html/common/User_Conce...c:trajectory-control
Minor nit, the plot can follow mechanical problems in a servo system
(where the backplot data is the actual position, not the commanded position)
Last edit: 28 Aug 2015 08:09 by PCW.
- Delron
28 Aug 2015 08:21 - 28 Aug 2015 08:22 #61849
by Delron
Thanks, right! So used to stepper systems.
But only for lost steps, right? Not flex.
Another reason to get position feedback on mine.
Cheers!
Cheers!
Last edit: 28 Aug 2015 08:22 by Delron. Reason: More info.
- altihu
01 Sep 2015 19:45 #61991
by altihu
Replied by altihu on topic got oval instead of circle cambam->linuxcnc
Thanks a lot, it was a wrong G64 setting, changed it from
G64 Blend Without Tolerance Mode
to
G64 P0.05 Blend With 0.05 (mm) Tolerance
to
Time to create page: 0.075 seconds
