changing default preview direction
- beltramidave
- Thank you received: 4
29 Oct 2015 01:39 #64408
by beltramidave
changing default preview direction was created by beltramidave
How can you change (permanently) the default view from perspective to z?
29 Oct 2015 17:18 #64430
by ArcEye
Replied by ArcEye on topic changing default preview direction
Approx line 3335 of ...../bin/axis (depends on your version, this was 2.7 I think)
Change commands.set_view_p() to commands.set_view_z() (or z2)
Axis sets to perspective by default and only reads the state of the toolbar buttons to set changes, so no external way of setting
except changing the code or clicking on Z when you start
if lathe:
commands.set_view_y()
else:
29 Oct 2015 18:12 #64434
by dgarrett
Replied by dgarrett on topic changing default preview direction
Alternatively, add the command to ~/.axisrc (instead of modifying the system file):
(Create the ~/.axisrc file if it doesn't exist)
- beltramidave
29 Oct 2015 18:55 #64440
by beltramidave
Replied by beltramidave on topic changing default preview direction
Thanks for the replies!
Where would I look for the /.axisrc file? How do I create it if it doesn't exist? I believe that I am running ver2.5.
29 Oct 2015 19:09 - 29 Oct 2015 19:10 #64443
by ArcEye
~/ is your home directory
If not present from a terminal
sudo echo "commands.set_view_z()" > ~/.axisrc
would be an all in one way
Last edit: 29 Oct 2015 19:10 by ArcEye.
The following user(s) said Thank You: beltramidave
- beltramidave
29 Oct 2015 21:33 #64456
by beltramidave
Thanks ArcEye, that worked!
Time to create page: 0.108 seconds
