Rotate the 4 axis XY:UV foam display??
09 Jul 2016 04:08 #77206 by jeffgar2000@gmail.com
Is it possible to rotate the 4 axis XY:UV foam display (axis_foam) so that the cuts are side by side instead of top and bottom? Mine seems to work fine up and down but I worry that I will make human mistakes since the machine display and the physical machine don't match.
Jeff
Time to create page: 0.090 seconds
