folders on NFS share missing in Axis File-Open...
13 Aug 2016 19:20 #78726
by trebor80
folders on NFS share missing in Axis File-Open... was created by trebor80
Hello,
on my LinuxCNC installation I have the very strange problem that some directories on an NFS mounted directory are not shown in Axis' File-Open dialog. I use LinuxCNC on Debian Weezy, originally installed Version was 2.6.something, now I have updated to 2.7.6 and the problem persists since then.
When I do File - Open... and browse to the NFS directory, nothing shows up. I can enter the Folder where I store the g-code files in the Filename field and it changes into the specified subfolder. Within this subfolder only the folders that were created before the initial Insallation of LinuxCNC (and have never been renamed) show up.
The Thunar file manager shows everything as it is. In various GTK open dialogboxes I have two entries for this NFS share where only one works but this is ok.
It might also help if I knew which library is used in Axis for the file-open to search for a solution there...
Please help!
Thanks and best Regards
Robert
Please help!
Robert
Time to create page: 0.087 seconds
