Make Dialog Box Wider
22 Dec 2016 21:01 #84574
by fc60
Make Dialog Box Wider was created by fc60
Greetings,
Using LinuxCNC 2.5.4 with Ubuntu 10.4
In the attached screenshot, notice where is says...
"Tool 2361, offset -6.6249, diameter 0.5"
"0.5" is actually "0.547". The text exceeds the window size.
So, where do I go to modify the window size?
There is a lot of unused space to the right of the Tool and Position information boxes
Cheers,
Dave
Cheers,
Dave
24 Dec 2016 19:13 #84673
by fc60
Replied by fc60 on topic Make Dialog Box Wider
Greetings,
Surely someone must know what file needs to be edited.
Cheers,
Dave
Cheers,
Dave
27 Dec 2016 22:12 #84766
Replied by andypugh on topic Make Dialog Box Wider
try editing /usr/share/axis/tcl/axis.tcl
Line 1332 in the version I am using.
Increase the width.
label .info.tool \
-anchor w \
-borderwidth 2 \
-relief sunken \
-textvariable tool \
-width 30
Increase the width.
The following user(s) said Thank You: fc60
29 Dec 2016 14:29 #84851
by fc60
Greetings Andy,
Many thanks for the editing information.
Now I have a new "bug". The file is owned by "root" and I have no idea what the "root" password is.
I sent a note to the folks that built the machine; but, I am not overly optimistic.
Cheers,
Dave
Cheers,
Dave
- Thank you received: 1369
29 Dec 2016 14:55 #84854
Replied by Todd Zuercher on topic Make Dialog Box Wider
You should be able to edit it using a sudo command with your user password.
Time to create page: 0.080 seconds
