Rename Menu-Button
- Holzwurm56
25 Jan 2017 09:05 #86599
by Holzwurm56
Rename Menu-Button was created by Holzwurm56
Hello,
does someone know in what kind of way I can change in the german axis Kühlung: > Fräsaggregat ; Kühlnebel > Fräse1 and Kühlmittel > Fräse2 ?
Hans
Hans
25 Jan 2017 13:43 #86613
Replied by andypugh on topic Rename Menu-Button
You should be able to edit the de.po file. (Which is where the translations are).
I don't know if that requires recompilation.
- Holzwurm56
25 Jan 2017 14:34 #86624
by Holzwurm56
Replied by Holzwurm56 on topic Rename Menu-Button
Hello andypugh,
I was looking with locate, find and other software for the de.po file, but I did not find the file.
Hans
Hans
25 Jan 2017 17:51 #86643
by newbynobi
Replied by newbynobi on topic Rename Menu-Button
Hallo Hans,
if you have downloaded the source code, the file is
~/linuxcnc-dev/src/po/de.po
after compiling the file is
/usr/share/locale/de/LC_MESSAGES/linuxcnc.mo
but you can not edit this file directly
Norbert
Norbert
25 Jan 2017 18:01 #86645
It looks like poedit can edit a .po and make a .mo, and optionally decompile the .mo to a .mo
bbpress.org/forums/topic/how-to-add-and-modify-mo-file/
Time to create page: 0.075 seconds
