Axis lathe - showing velocity and DTG
13 Jan 2018 05:09 #104384
by kentavv
Axis lathe - showing velocity and DTG was created by kentavv
Hi. In lathe mode (I've not checked mill mode), when I have Show Offsets enabled or am on the DRO tab, DTG is shown for the X and Z axes, but axis velocity is not shown. With Show Offsets not enabled, DTG and velocity are shown but not for each axis.
Is this the correct behavior (in case I've messed something up) and is there a way I can add axis velocities when Show Offsets is enabled and on the DRO page?
Thank you, Kent
Thank you, Kent
- skunkworks
- Thank you received: 148
13 Jan 2018 16:06 #104389
by skunkworks
Replied by skunkworks on topic Axis lathe - showing velocity and DTG
That is a known bug.
13 Jan 2018 17:11 #104391
by kentavv
Replied by kentavv on topic Axis lathe - showing velocity and DTG
OK, would fixing the bug be a reasonable challenge for a newbie or are there major obstacles?
- Thank you received: 1370
14 Jan 2018 02:31 - 14 Jan 2018 02:40 #104411
Replied by Todd Zuercher on topic Axis lathe - showing velocity and DTG
Considering it has been that way for longer than I have used Linuxcnc (more than 8 years) it probably is not an easy fix.
Last edit: 14 Jan 2018 02:40 by Todd Zuercher.
14 Jan 2018 03:01 #104413
by kentavv
Thanks Todd, that's too bad. It would be nice to find some simple task to tackle.
In case it's of some help to the next person, here's how I hacked it in for the time being. Seems to work with jogs and feed overrides, but not as nicely integrated as with mill mode.
custom_postgui.hal
custompanel.xml
custom_postgui.hal
loadrt scale names=scale.x-vel,scale.z-vel
addf scale.x-vel servo-thread
addf scale.z-vel servo-thread
setp scale.x-vel.gain 60
setp scale.z-vel.gain 60
net x-velocity-ups axis.0.joint-vel-cmd scale.x-vel.in
net z-velocity-ups axis.2.joint-vel-cmd scale.z-vel.in
net x-velocity-upm scale.x-vel.out pyvcp.x-velocity-upm
net z-velocity-upm scale.z-vel.out pyvcp.z-velocity-upm
custompanel.xml
<hbox>
<label>
<text>"X Velocity"</text>
<font>("Helvetica", 20)</font>
</label>
<number>
<halpin>"x-velocity-upm"</halpin>
<format>"+3.2f"</format>
</number>
</hbox>
<hbox>
<label>
<text>"Z Velocity"</text>
</label>
<number>
<halpin>"z-velocity-upm"</halpin>
</number>
</hbox>
16 Jan 2018 19:39 #104562
Replied by cmorley on topic Axis lathe - showing velocity and DTG
This is actually a one line change in glcanon.py to get velocity to shown in the offsets page.
Is there a bug tracker for this problem? never heard of it before.
some where near line 1576:
If someome one could confirm the behavior I can push the fix
Chris M
if self.get_show_machine_speed():
posstrs.append(format % ("Vel", spd))
droposstrs.append(diaformat % ("Vel", spd)) # <-- add this line
Chris M
The following user(s) said Thank You: kentavv
23 Jan 2018 05:57 #104873
by kentavv
Hi Chris, I tried your suggestion and it worked perfectly. Looks much more like the mill mode does. I also learned about glcanon.py, which looks very interesting. Is it OK to modify this directly to add new functionality or is a there a recommended way that's safe from being overwritten during an upgrade? I have been using custompanel.xml and custom_postgui.hal. Thank you, Kent
23 Jan 2018 06:35 - 23 Jan 2018 06:36 #104874
This file would be overwritten on upgrades.
The typical way to maintain customizations of this type is to use a git clone of linuxcnc, create your own branch and run it Run-In-Place (RIP) - this is exactly what developers do.
In this way you can control what gets changed and when.
In this case when I get some time I will look to push the fix.
Chris M
Chris M
Last edit: 23 Jan 2018 06:36 by cmorley.
24 Jan 2018 02:33 #104929
I pushed the fix to master branch.
Chris M
Chris M
Time to create page: 0.109 seconds
