Adding a status tab for MESA card
20 Jan 2018 17:26 #104747
by kor
Adding a status tab for MESA card was created by kor
I decided to get familiar with the HAL and the user interface. As an exercise i devided to make a tab showing me the status of my mesa 7i76E input pins. (Which might help me later when I build the complete controll cabinett)
So I made a simple UI with glade having some status leds saved it as mesa7i76E.ui
than I added those lines to the ini:which made my tab appear
Afterwards I made a hal file called mesa7i76E.haland finally added the source mesa7i76E.hal to the postgui_call_list.hal
Well the pannel with the 2 leds is there, but it doesn t do anything.
did I miss a step or how can I simply show the status of an input pin in the gui?
<?xml version="1.0" encoding="UTF-8"?>
<interface>
<requires lib="gtk+" version="2.24"/>
<!-- interface-requires gladevcp 0.0 -->
<!-- interface-naming-policy project-wide -->
<object class="GtkWindow" id="window1">
<property name="can_focus">False</property>
<child>
<object class="GtkTable" id="table1">
<property name="visible">True</property>
<property name="n_rows">27</property>
<property name="n_columns">8</property>
<child>
<object class="HAL_LED" id="LED_di05">
<property name="led_blink_rate">0</property>
<signal name="hal-pin-changed" handler="on_LED_di05_hal_pin_changed" swapped="no"/>
</object>
<packing>
<property name="left_attach">6</property>
<property name="right_attach">7</property>
<property name="top_attach">21</property>
<property name="bottom_attach">22</property>
</packing>
</child>
<child>
<object class="HAL_LED" id="LED_di08">
</object>
<packing>
<property name="top_attach">18</property>
<property name="bottom_attach">19</property>
</packing>
</child>
<child>
<object class="GtkLabel" id="label1">
<property name="label" translatable="yes">TB6 di08</property>
</object>
<packing>
<property name="left_attach">7</property>
<property name="right_attach">8</property>
</packing>
</child>
<child>
<object class="GtkLabel" id="label2">
<property name="label" translatable="yes">TB6 di05</property>
</object>
<packing>
</packing>
</child>
<child>
<object class="GtkLabel" id="label3">
<property name="label" translatable="yes">TB6 ai00</property>
</object>
<packing>
<property name="top_attach">26</property>
<property name="bottom_attach">27</property>
</packing>
</child>
<child>
<placeholder/>
</child>
<child>
<placeholder/>
</child>
</object>
</child>
</object>
</interface>
#my own panels
EMBED_TAB_NAME=7i76E
EMBED_TAB_COMMAND=halcmd loadusr -Wn gladevcp gladevcp -c vcp7i76 -x {XID} -u ./gladevcp/hitcounter.py ./mesa7i76E.ui
# HAL commands for MESA7i76E VCP
net LED_di05 hm2_7i76e.0.7i76.0.0.input-05 <= vcp7i76.LED_di05
net LED_di05 hm2_7i76e.0.7i76.0.0.input-08 <= vcp7i76.LED_di08
21 Jan 2018 11:23 #104772
Replied by andypugh on topic Adding a status tab for MESA card
If you check Machine->Show Hal Configuration does it appear that the connections have been made?
My suspicion is that the postgui call list isn't being called.
21 Jan 2018 12:24 #104779
by kor
Replied by kor on topic Adding a status tab for MESA card
I have no idea how it should look.
So under the al configuration I found my vcp7i76 and the 2 LEDs.
for each LED it says owner: 52 Type: bit Dir: in Name: vcp7i76.LED_di0X
So I geuss you are right. But I don't know how it should look like and how to fix it.
21 Jan 2018 12:26 #104780
Is your Postgut Hal file referenced in the INI file?
21 Jan 2018 12:27 #104781
by kor
Yes in the ini under HAL it says POSTGUI_HALFILE = postgui_call_list.hal
21 Jan 2018 12:44 #104783
by BigJohnT
Replied by BigJohnT on topic Adding a status tab for MESA card
In the show hal configuration add the two input pins to the watch window then toggle the inputs to see if you have it wired up right. If you don't see <== and a signal name after the pin name in the show window then your net line has not been read and no connection has been made. Attach your hal and ini files.
JT
JT
21 Jan 2018 12:45 #104784
Do you see the LED_di05 etc signals in the signals section of the HAL config?
You can also try adding the inputs and the leds to the “Watch” tab to make sure that they are actually changing state.
21 Jan 2018 13:12 #104785
by kor
Sry bigJohnT I am completly new to this so I don't really now what you want me to do. I am doing this mainly to learn.
Here is my HALand here is my ini:
Here is my HAL
# Generated by PNCconf at Fri Jan 19 22:22:46 2018
# Änderungen an dieser Datei werden beim nächsten
# overwritten when you run PNCconf again
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="192.168.1.121" config="firmware=hm2/7i76/7i76e.BIT num_encoders=1 num_pwmgens=0 num_stepgens=2 sserial_port_0=00xxxx"
setp hm2_7i76e.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.z,pid.s
addf hm2_7i76e.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_7i76e.0.write servo-thread
setp hm2_7i76e.0.dpll.01.timer-us -50
setp hm2_7i76e.0.stepgen.timer-number 1
# external output signals
# external input signals
# --- MAX-Z ---
net max-z <= hm2_7i76e.0.7i76.0.0.input-04
# --- HOME-Z ---
net home-z <= hm2_7i76e.0.7i76.0.0.input-08
# --- CYCLE-START ---
net cycle-start <= hm2_7i76e.0.7i76.0.0.input-09
# --- ABORT ---
net abort <= hm2_7i76e.0.7i76.0.0.input-10
# --- SINGLE-STEP ---
net single-step <= hm2_7i76e.0.7i76.0.0.input-11
# JOINT X
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
setp pid.x.maxerror .0005
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-vel-cmd => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
net x-output => pid.x.output
# Step Gen signals/setup
setp hm2_7i76e.0.stepgen.01.dirsetup [JOINT_0]DIRSETUP
setp hm2_7i76e.0.stepgen.01.dirhold [JOINT_0]DIRHOLD
setp hm2_7i76e.0.stepgen.01.steplen [JOINT_0]STEPLEN
setp hm2_7i76e.0.stepgen.01.stepspace [JOINT_0]STEPSPACE
setp hm2_7i76e.0.stepgen.01.position-scale [JOINT_0]STEP_SCALE
setp hm2_7i76e.0.stepgen.01.step_type 0
setp hm2_7i76e.0.stepgen.01.control-type 1
setp hm2_7i76e.0.stepgen.01.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp hm2_7i76e.0.stepgen.01.maxvel [JOINT_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd <= joint.0.motor-pos-cmd
net x-vel-cmd <= joint.0.vel-cmd
net x-output <= hm2_7i76e.0.stepgen.01.velocity-cmd
net x-pos-fb <= hm2_7i76e.0.stepgen.01.position-fb
net x-pos-fb => joint.0.motor-pos-fb
net x-enable <= joint.0.amp-enable-out
net x-enable => hm2_7i76e.0.stepgen.01.enable
# ---setup home / limit switch signals---
net x-home-sw => joint.0.home-sw-in
net x-neg-limit => joint.0.neg-lim-sw-in
net x-pos-limit => joint.0.pos-lim-sw-in
# JOINT Z
setp pid.z.Pgain [JOINT_1]P
setp pid.z.Igain [JOINT_1]I
setp pid.z.Dgain [JOINT_1]D
setp pid.z.bias [JOINT_1]BIAS
setp pid.z.FF0 [JOINT_1]FF0
setp pid.z.FF1 [JOINT_1]FF1
setp pid.z.FF2 [JOINT_1]FF2
setp pid.z.deadband [JOINT_1]DEADBAND
setp pid.z.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror .0005
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-vel-cmd => pid.z.command-deriv
net z-pos-fb => pid.z.feedback
net z-output => pid.z.output
setp hm2_7i76e.0.stepgen.00.dirsetup [JOINT_1]DIRSETUP
setp hm2_7i76e.0.stepgen.00.dirhold [JOINT_1]DIRHOLD
setp hm2_7i76e.0.stepgen.00.steplen [JOINT_1]STEPLEN
setp hm2_7i76e.0.stepgen.00.stepspace [JOINT_1]STEPSPACE
setp hm2_7i76e.0.stepgen.00.position-scale [JOINT_1]STEP_SCALE
setp hm2_7i76e.0.stepgen.00.step_type 0
setp hm2_7i76e.0.stepgen.00.control-type 1
setp hm2_7i76e.0.stepgen.00.maxaccel [JOINT_1]STEPGEN_MAXACCEL
setp hm2_7i76e.0.stepgen.00.maxvel [JOINT_1]STEPGEN_MAXVEL
net z-pos-cmd <= joint.1.motor-pos-cmd
net z-vel-cmd <= joint.1.vel-cmd
net z-output <= hm2_7i76e.0.stepgen.00.velocity-cmd
net z-pos-fb <= hm2_7i76e.0.stepgen.00.position-fb
net z-pos-fb => joint.1.motor-pos-fb
net z-enable <= joint.1.amp-enable-out
net z-enable => hm2_7i76e.0.stepgen.00.enable
net home-z => joint.1.home-sw-in
net z-neg-limit => joint.1.neg-lim-sw-in
net max-z => joint.1.pos-lim-sw-in
# SPINDLE S
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb-rps => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net axis-select-x halui.axis.x.select
net jog-x-pos halui.axis.x.plus
net jog-x-neg halui.axis.x.minus
net jog-x-analog halui.axis.x.analog
net x-is-homed halui.joint.0.is-homed
net axis-select-z halui.axis.z.select
net jog-z-pos halui.axis.z.plus
net jog-z-neg halui.axis.z.minus
net jog-z-analog halui.axis.z.analog
net z-is-homed halui.joint.1.is-homed
net jog-selected-pos halui.axis.selected.plus
net jog-selected-neg halui.axis.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---jogwheel signals to mesa encoder - shared MPG---
net axis-selected-count <= hm2_7i76e.0.encoder.00.count
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---manual tool change signals---
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
[EMC]
MACHINE = my_Lathe_7i76E
DEBUG = 0
VERSION = 1.0
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/kor/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
LATHE = 1
DEFAULT_LINEAR_VELOCITY = 6.000000
MAX_LINEAR_VELOCITY = 25.000000
MIN_LINEAR_VELOCITY = 0.500000
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
#my own panels
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_eth
# BOARD0=7i76e
[HAL]
HALUI = halui
HALFILE = my_Lathe_7i76E.hal
HALFILE = custom.hal
SHUTDOWN = shutdown.hal
[HALUI]
[KINS]
JOINTS = 2
KINEMATICS = trivkins coordinates=XZ
[TRAJ]
COORDINATES = X Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 5.00
MAX_LINEAR_VELOCITY = 50.00
NO_FORCE_HOMING = 1
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Joint 0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 50.0
MAX_ACCELERATION = 150.0
STEPGEN_MAXVEL = 62.50
STEPGEN_MAXACCEL = 187.50
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP = 4000
DIRHOLD = 4000
STEPLEN = 4000
STEPSPACE = 4000
STEP_SCALE = 400.0
MIN_LIMIT = -3000000.0
MAX_LIMIT = 0.01
HOME_OFFSET = 0.0
# Axis X
[AXIS_X]
MAX_VELOCITY = 50.0
MAX_LIMIT = 0.01
# Joint 1
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 50.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 4000
DIRHOLD = 4000
STEPLEN = 4000
STEPSPACE = 4000
STEP_SCALE = 400.0
MIN_LIMIT = -1e+11
MAX_LIMIT = 0.01
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = -1.000000
HOME_LATCH_VEL = -0.500000
HOME_FINAL_VEL = 0.000000
HOME_USE_INDEX = NO
# Axis Z
[AXIS_Z]
MAX_VELOCITY = 50.0
MIN_LIMIT = -1e+11
MAX_LIMIT = 0.01
# Spindle
[SPINDLE_9]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2000
21 Jan 2018 13:15 #104786
by kor
Andy under show hal and Signals is a bunch of stuff but no LED_di05 or di08
21 Jan 2018 14:02 #104788
Start LinuxCNC from the command line (command "linuxcnc") and see if you get any complaints about files that it can't find.
Also try calling your 7i76E.hal file directly, rather than with the "source" command in a call list. (ie replace the call_list file in the INI with the 7i76E file name)
Time to create page: 0.120 seconds
