Axis Crash on startup LM 18-18.3
This is really starting to do my head in, I upgraded my machine from LM 17.3(working 32bit RTAI) -> 18 -> 18.3. Ran a latency test for a day everything was fine but then tried to start linuxcnc using Axis as the gui and got constant crashes like this
File "/usr/bin/axis", line 3640, in <module>
o = MyOpengl(widgets.preview_frame, width=400, height=300, double=1, depth=1)
File "/usr/bin/axis", line 383, in __init__
Opengl.__init__(self, *args, **kw)
File "/usr/lib/pymodules/python2.7/rs274/OpenGLTk.py", line 164, in __init__
apply(RawOpengl.__init__, (self, master, cnf), kw)
File "/usr/lib/pymodules/python2.7/rs274/OpenGLTk.py", line 112, in __init__
Togl.__init__(self, master, cnf, **kw)
File "/usr/lib/pymodules/python2.7/rs274/OpenGLTk.py", line 38, in __init__
Widget.__init__(self, master, 'togl', cnf, kw)
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 2094, in __init__
(widgetName, self._w) + extra + self._options(cnf))
_tkinter.TclError: NULL main window
Installed buildbot 2.7 RTAI same crashes
Installed linuxcnc 2.7.12 RTAI this morning, same crashes
Installed buildbot 2.8 RTAI just now with the same crashes (see attached for full log)
The machine is vanilla, works perfectly when I use my fallback install of LM 13.1 (precise) so it's not hardware.
Seems to be something to do with OpenGL as if I use tklinucnc as my interface I can use the machine without issue.
Please help
- Thank you received: 5972
Would like to use the 3.4.9 kernel as I get around 5000 latency with it, around 16,000 with the 3.16 and around 26,000 with the 4.1 kernel.
