Screen like Mach
- pavelshakal
27 Aug 2018 09:51 - 27 Aug 2018 09:52 #116643
by pavelshakal
Adding custom buttons was created by pavelshakal
Good day to all. I'm a milling machine but not a programmer, I switched to Linuxcnc with match3. and not how I can not understand how to change the screen since the original is simply too useless. Could I have been pushed into the finished screen with the functions similar to the match3 and how to install it. Thank you in advance.
By the way installing Linuxcnc is as simple as twice two compared to match3
Last edit: 27 Aug 2018 09:52 by pavelshakal.
- Thank you received: 1370
29 Aug 2018 15:55 #116777
Replied by Todd Zuercher on topic Adding custom buttons
Having never used Mach3, what features do you need or want that are missing?
31 Aug 2018 21:42 #116930
by BigJohnT
Replied by BigJohnT on topic Adding custom buttons
Take a look in the Documents in the User Interfaces section for the different UI's that are available.
JT
JT
- Thank you received: 5987
31 Aug 2018 21:48 #116932
Replied by tommylight on topic Adding custom buttons
He IS a milling machine !!!Good day to all. I'm a milling machine ........
The following user(s) said Thank You: HalaszAttila
- pavelshakal
12 Sep 2018 13:00 #117390
by pavelshakal
Replied by pavelshakal on topic Adding custom buttons
Sorry for the translation! )))
- pavelshakal
12 Sep 2018 13:03 #117391
by pavelshakal
I need a button "go to home" , processing speed indicator and processing time indicator
- pavelshakal
12 Sep 2018 13:05 #117392
by pavelshakal
The rest suits me
12 Sep 2018 13:44 - 12 Sep 2018 13:48 #117397
I use the standard Axis user interface on the routers I've retrofitted and by adding an additional VCP (virtual control pannel) to the Axis UI I have added those features.
And there are instructions in the documentation how to build similar VCP panels and integrate them with your user interface of choice.
Here is a screen shot of the UI used on one of our machines. The time it takes to do a run is shown at the top right (cycle time), a button that returns the machine to the home/park position (and resets some other settings) is the "CLEAR" button. (the machine's current velocity is part of the built in DRO, so isn't added to the VCP.)
Last edit: 12 Sep 2018 13:48 by Todd Zuercher.
- pavelshakal
12 Sep 2018 14:27 #117401
by pavelshakal
cool !!! How to do this? ))))
- pavelshakal
12 Sep 2018 14:30 #117402
by pavelshakal
can it be possible for non-programmers
Time to create page: 0.111 seconds
