Noob having trouble modifying Configs
- ARKLATEXPITS
03 Nov 2018 16:47 #119867
by ARKLATEXPITS
Noob having trouble modifying Configs was created by ARKLATEXPITS
Which is the best and easiest Config for plasma. I've tried modifying sample configs to no avail. I've download prewritten configs from the forum. PLEASE HELP!!
- Online
- Thank you received: 5979
03 Nov 2018 16:56 #119868
Replied by tommylight on topic Noob having trouble modifying Configs
David,
Tell us more about the machine you are trying to configure, like motion, drives, motors, wiring, setup, plasma, etc.
- ARKLATEXPITS
03 Nov 2018 17:04 #119869
by ARKLATEXPITS
Replied by ARKLATEXPITS on topic Noob having trouble modifying Configs
5FT X 9 FT Table, no THC yet, will be getting a Proma. I'm using 1/16 micro-stepping, belt drive for the X and Y and Ball screw for the Z.
19 Nov 2018 15:09 #120994
by BigJohnT
Replied by BigJohnT on topic Noob having trouble modifying Configs
If it is a stepper machine just run the Stepconf Wizard and create your configuration. If it is a servo machine use Pncconf. Sample configs are usually not the best place to start unless you know how to modify them.
To get good help you must spell out what you tried, what you expected and what you got...
JT
JT
- snugglylovemuffin
- Thank you received: 11
30 Nov 2018 00:38 #121615
by snugglylovemuffin
Replied by snugglylovemuffin on topic Noob having trouble modifying Configs
Hahahaha, I just got my THC figured out. Going to need to know more about your components. Toma is a great place to start; I can help you with modifying it to your own machine, as best I can anyway.
Time to create page: 0.212 seconds
