Servo Tuning wont open
14 Nov 2018 01:29 #120645 by 3D-Master
Hello,
i hope i am not getting annoying but i cannot open the Servo Tuning tab. nothing happens, restarted linuxcnc and the whole pc but still doesnt open.
i have searched in the internet but havent found a solution.
14 Nov 2018 01:48 #120646 by PCW
Replied by PCW on topic Servo Tuning wont open
Do you mean the calibrate menu in Axis?
This allows you to conveniently tweak tuning parameters in real time
and give you the option to save them back to your ini file
14 Nov 2018 02:16 - 14 Nov 2018 02:18 #120649 by 3D-Master
Replied by 3D-Master on topic Servo Tuning wont open
yes but when i click on it, nothing happens. The window simply doesnt pop up
Last edit: 14 Nov 2018 02:18 by 3D-Master.
14 Nov 2018 04:30 #120653 by PCW
My guess is that its some issue with your .ini file
can you post it here?
14 Nov 2018 12:54 #120669 by andypugh
Replied by andypugh on topic Servo Tuning wont open
It looks for certain entries in the INI file.
Hmmm... I wonder if those entries have different names in 2.8?
Seems not, this old bug tracker indicates that something happened, just not exactly the right thing.
github.com/LinuxCNC/linuxcnc/issues/94
14 Nov 2018 13:14 - 14 Nov 2018 13:16 #120674 by dgarrett
Replied by dgarrett on topic Servo Tuning wont open
github.com/LinuxCNC/linuxcnc/commit/f0e10a37a
github.com/LinuxCNC/linuxcnc/commit/4d1cdd76d
github.com/LinuxCNC/linuxcnc/commit/740c4252a
740c4252a:
Now support additional stanza names:
   [JOINT_N]name=value (suffix N is a joint number)
   [AXIS_L]name=value  (suffix L is an axis letter)
   [TUNE]name=value    (no suffixes for the [TUNE] stanza)
Last edit: 14 Nov 2018 13:16 by dgarrett.
14 Nov 2018 13:29 - 14 Nov 2018 13:29 #120676 by 3D-Master
Here is my ini file
Last edit: 14 Nov 2018 13:29 by 3D-Master.
14 Nov 2018 14:12 #120680 by 3D-Master
I have linuxcnc 2.7.14
15 Nov 2018 18:39 #120767 by 3D-Master
740c4252a:
so do i have to edit the file/s manually?
15 Nov 2018 22:55 #120790 by alan_3301
Replied by alan_3301 on topic Servo Tuning wont open
Have you tried running linuxcnc from the console, and watching for any error messages when you click the configuration button?
The following user(s) said Thank You: 3D-Master
Time to create page: 0.083 seconds
