2.8.0-pre1 XXYZ gantry Axis preview toolpath stretched in the X direction
05 Feb 2020 15:22 #156597
by shasse
Hi all. I am running a 2.8.0-pre1 XXYZ servo gantry configuration generated via pncconf. In general the machine is working fine, but when viewing the toolpaths in the Axis preview GUI, the tool path appears to be stretched twice as long in the X direction. The parts cut fine, the extents are shown properly in the preview, but the toolpath is stretched.
Any suggestions on what might be causing this?
Thanks!
Scott
Thanks!
Scott
05 Feb 2020 15:35 #156598
by shasse
Replied by shasse on topic 2.8.0-pre1 XXYZ gantry Axis preview toolpath stretched in the X direction
I should add, I looked through github issues and this forum and I wasn't able to find anyone with a similar problem.
Thanks!
Thanks!
- Thank you received: 5979
05 Feb 2020 16:37 #156601
Replied by tommylight on topic 2.8.0-pre1 XXYZ gantry Axis preview toolpath stretched in the X direction
Screenshot ???
06 Feb 2020 02:27 #156610
by shasse
I won't be by the machine for a couple of days, but I'll get a screenshot as soon as I am able.
- Thank you received: 1370
06 Feb 2020 03:23 #156611
Replied by Todd Zuercher on topic 2.8.0-pre1 XXYZ gantry Axis preview toolpath stretched in the X direction
Might just be a screen resolution issue. Try taking a screen shot and look at it on another computer. Does the screen shot look different on another pc?
06 Feb 2020 04:04 #156613
by shasse
The rest of the screen is normal, I can even see the extents of the tool path in the preview tab labeled with their values, and the extents are correct and to scale. The actual tool path however is twice as long in the X direction, no matter how I rotate in the preview view.
I think that rules out a screen resolution issue.
You are right that a screen shot will make this more clear. I'll try to get one as soon as possible.
Thanks!
Scott
Thanks!
Scott
06 Feb 2020 12:58 #156634
I have an idea of what your problem may be. Could you post a copy of your ini file.
06 Feb 2020 14:04 #156636
by shasse
The ini file is here:
github.com/Sector67/router-conversion/bl...er/config/router.ini
and you can see the rest of the config at:
github.com/Sector67/router-conversion/blob/master/config
Thanks!
Scott
Thanks!
Scott
06 Feb 2020 19:40 #156648
In the display section of your ini file change the GEOMETRY = xxyz to GEOMETRY = xyz
09 Feb 2020 04:04 #156817
by shasse
That was the problem. Changing to GEOMETRY = xyz resolved it.
Thanks Todd!
Scott
Thanks Todd!
Scott
Time to create page: 0.157 seconds
