Default settings when loading
07 Apr 2020 23:42 #163122
by mooser
Default settings when loading was created by mooser
Where are the default settings stored when LinuxCNC / AXIS loads? I work in diameter and keep forgetting to set the G7
I've looked in the docs but only see what the defaults are not really where they can be changed?
M
M
07 Apr 2020 23:46 #163124
Replied by cmorley on topic Default settings when loading
linuxcnc.org/docs/2.7/html/config/ini-co...ml#_rs274ngc_section
[RS274NGC]
RS274NGC_STARTUP_CODE =
Chris
[RS274NGC]
Chris
08 Apr 2020 00:19 #163131
by mooser
Replied by mooser on topic Default settings when loading
Startup, I kept looking for default
Thanks I'll add that tomorrow
M
M
09 Apr 2020 02:55 #163291
by mooser
Worked perfect, thanks
M
M
Time to create page: 0.751 seconds
