How to change the Coordinate Resolution
10 Jul 2020 06:51 #174188
by NC4cnc
How to change the Coordinate Resolution was created by NC4cnc
Hi guys,
I've been using LinuxCNC for quite a while now but had never bothered making changes to the default AXIS user interface that is already in the .ini file.
Is there any way to increase the resolution displayed in the coordinate display, like now it's 4 decimal places: 0.0001" to 5 decimal places: 0.00001? The axes' resolution is 0.0000046875"/step and the built in gearing will make fine movements on the motor shaft.
I'm working on using the milling machine for coordinate measurement and put a video microscope in place of the spindle to measure die samples.
Any advice will be highly appreciated.
Thanks,
Nuki
Thanks,
Nuki
10 Jul 2020 09:54 - 10 Jul 2020 09:54 #174195
by phillc54
Replied by phillc54 on topic How to change the Coordinate Resolution
See dro_format here for 2.8 and master.
linuxcnc.org/docs/devel/html/config/ini-...tml#_display_section
Last edit: 10 Jul 2020 09:54 by phillc54.
11 Jul 2020 04:02 #174283
by NC4cnc
Replied by NC4cnc on topic How to change the Coordinate Resolution
Hi Phil,
I'm running the 2.7.0 version and since the line items are not included in the ini file. I added these two.
DRO_FORMAT_MM = %+08.6f
DRO_FORMAT_IN = %+06.5f
Did see any changes though during the runtime.
Also 2.8 and master versions are yet to be released. Any advice for 2.7 versions?
Thanks,
Nuki
Thanks,
Nuki
11 Jul 2020 04:07 #174284
by phillc54
This feature is not available in 2.7
You can either wait until 2.8 is released which should happen in the not to distant future or upgrade to 2.8 via the buildbot.
buildbot.linuxcnc.org/
16 Jul 2020 09:39 #174819
by NC4cnc
Hi Phil,
Been away for work and would like to thank you for your reply. I have to setup a separate PC for experimentation on the 2.8 version. Will get back to you later of the results.
All the best. Nuki
All the best. Nuki
Time to create page: 0.134 seconds
