Plasma Axis - Tool cone on Plot display not moving during homing
07 Aug 2020 21:29 #177655
by ts_7
I have experienced Tool cone stopped moving on Plot display to follow position during homing. Unfortunately I did not succeed to find any way to solve this. Do you anyone have any idea? Could this be related to any usr/share/... files.
I am using Linuxcnc 2.8 on Debian 9.
Thank you for any guidance ...
- Thank you received: 5972
13 Aug 2020 07:02 #178071
Replied by tommylight on topic Plasma Axis - Tool cone on Plot display not moving during homing
Just checked, it does not move, most probably due to the fact that it does not know where exactly the machine is prior to homing.
31 Aug 2020 20:24 - 31 Aug 2020 21:19 #180217
by ts_7
Replied by ts_7 on topic Plasma Axis - Tool cone on Plot display not moving during homing
Thank you very much. I will try to sort it out.
This is only after I start Linuxcnc application. Could that be that I am homing with not known position of machine while having the coordinates system already defined? If so, could that be related to default ngc being open at startup?
Last edit: 31 Aug 2020 21:19 by ts_7.
Time to create page: 0.073 seconds
