I dont have axis interface in Applications-CNC
30 Aug 2020 21:43 #180109
by kevin19
I dont have axis interface in Applications-CNC was created by kevin19
Hello, I have installed linuxcnc 2.9 but I don’t have the axis interface in the Applications. Inside Applications-CNC, I only have “Documentation”, “pncconf wizard” and “stepconf wizard”.Can anyone tell me what should I do to open the axis interface?
- BeagleBrainz
- User is blocked
- Thank you received: 570
30 Aug 2020 22:20 #180113
by BeagleBrainz
Replied by BeagleBrainz on topic I dont have axis interface in Applications-CNC
So only 3 entries, no entry titled "Linuxcnc" along with the three you mentioned.
Open a terminal and runwhich opens the the linuxcnc configuration selector.
Sometimes, for reasons, logging out & logging back in can fix up the menu entries.
One tip, mentioning your current linux distro & version can help.
linuxcnc
- Thank you received: 5972
30 Aug 2020 23:07 #180117
Replied by tommylight on topic I dont have axis interface in Applications-CNC
LinuxCNC is for some unknown reason in the "accessories" menu.
03 Sep 2020 09:21 #180504
by kevin19
Replied by kevin19 on topic I dont have axis interface in Applications-CNC
Thank you!
