Axis real system emulation
04 Sep 2020 15:30 #180689
by kevin19
Axis real system emulation was created by kevin19
Hello, as I don't have the 6i25 mesa card and the gecko driver 214V with me, I would like to create a virtual machine(like Axis) to just emulate the real system and see how it works with the 4 XYZZ axis and the whb04 pendant in linuxcnc 2.9. I would like to know how to do it. I did the pncconfig and I am attaching the ''hal'' and ''ini'' file to this message. And when I launch the file after the pnc configuration, I get the following error message put in attachment.
- Thank you received: 5972
04 Sep 2020 16:03 #180697
Replied by tommylight on topic Axis real system emulation
I am pretty sure i have seen the same question today on this forum, but not sure if it was the same person, so please stop double or triple posting the same things.
Use stepconf to create a simulated machine config, on the second page there is a selector for exactly that use.
04 Sep 2020 17:37 #180720
Replied by cmorley on topic Axis real system emulation
There is no simulated config available for Mesa products.
As Tommy said you can build a simulated custom config with stepconf or just use a sample config.
The following user(s) said Thank You: tommylight, Aciera
- Mike_Eitel
- Thank you received: 185
05 Sep 2020 09:55 #180796
by Mike_Eitel
Replied by Mike_Eitel on topic Axis real system emulation
Never did it, but i think it should be possible to have a .comp file with all the pin names.
Or not?
Mike
Or not?
Mike
07 Sep 2020 03:31 #181085
It's possible yes. That's what i did for the simulated parallel port component
Time to create page: 0.097 seconds
