Adding Buttons to Axis
28 Sep 2020 14:07 #184173
by Blume
Adding Buttons to Axis was created by Blume
i want to add some Buttons with Glade to my axis Panel. I want a Button M3 thats works when my Program is still running. I just don't know how to do it so that it works.
- Thank you received: 5972
28 Sep 2020 21:05 #184216
Replied by tommylight on topic Adding Buttons to Axis
I do not think the M3 will work when in Auto mode and the program is running, but i might be wrong.
I am sure it does not work in Axis GUI.
29 Sep 2020 06:22 #184241
by Blume
Replied by Blume on topic Adding Buttons to Axis
Hi.
Sometimes when I start the code of a certain place The m3 command is not active. I must to start the spindle manual
29 Sep 2020 07:02 - 29 Sep 2020 07:15 #184244
Replied by rodw on topic Adding Buttons to Axis
YOU probably do not have a feedrate set
eg
M3 S100
eg
M3 S100
Last edit: 29 Sep 2020 07:15 by rodw.
29 Sep 2020 07:15 #184246
by Clive S
Do you mean S100
Replied by Clive S on topic Adding Buttons to Axis
eg
M3 F100
Do you mean S100
29 Sep 2020 07:16 #184248
I knew I had something wrong! You can tell I have never used a spindle!
ANd the spindle at speed signal must be activated before it will move
29 Sep 2020 14:39 #184298
by Reinhard
When you want to start anywhere in the file, you have to think, what commands/informations the machine needs to workout what you want.
Think of
creating a fancy button is not the right solution to your problem.
Replied by Reinhard on topic Adding Buttons to Axis
You can NOT start at arbitrary file position.Sometimes when I start the code of a certain place The m3 command is not active.
Think of
- units of measure (G20 inch/ G21 mm)
- distance mode (G90 absolute / G91 relative)
- Coordinate system (G53 - G59)
- Spindle Speed (i.e. S20000)
- feed (F300)
- enable spindle (M3)
- cooling (M7/M8)
- tool length compensation (G43)
- tool radius compensation (G41/G42)
