5axis router with Y-slave axis XYZAB
21 Nov 2020 09:23 #189965
by joseph
5axis router with Y-slave axis XYZAB was created by joseph
I have an 5 axis router with Y slave axis. The machine was running on cncusb from planet, i want to change it to linux cnc because print board burn.I'm complete newbie never work with linux cnc.can somebody help me how to set up de gui interface.i'm on debian stretch and linux cnc 2.8
Joseph
Joseph
21 Nov 2020 09:39 #189967
Replied by Aciera on topic 5axis router with Y-slave axis XYZAB
Do you need 5 axis fully interpolated ?
For the interpolated setup you would need to write the kinematic yourself as for now only xyzac and xyzbc come with the installation and you need XYYZAB.
Otherwise all you need is to setup XYZAB and the slave axis Y in the INI
The following user(s) said Thank You: joseph
21 Nov 2020 13:48 #189973
by joseph
Replied by joseph on topic 5axis router with Y-slave axis XYZAB
can i not use the 9 axis interface use or connect only total 6 axis and duplicate Y axis and reverse it.
21 Nov 2020 16:00 #189985
Ok so I presume you don't need TCP.
You need to change this in the INI:
[KINS]
JOINTS = 6
KINEMATICS = trivkins coordinates=XYYZAB kinstype=BOTH
[TRAJ]
COORDINATES = X Y Y Z A B
[AXIS_X]
[JOINT_0]
[AXIS_Y]
[JOINT_1]
[JOINT_2]
[AXIS_Z]
[JOINT_3]
[AXIS_A]
[JOINT_4]
[AXIS_C]
[JOINT_5]
[KINS]
JOINTS = 6
[TRAJ]
[AXIS_X]
[JOINT_0]
[AXIS_Y]
[JOINT_1]
[JOINT_2]
[AXIS_Z]
[JOINT_3]
[AXIS_A]
[JOINT_4]
[AXIS_C]
[JOINT_5]
21 Nov 2020 16:05 #189987
by joseph
Aciera,
Thanks its working.
Joseph
Thanks its working.
Joseph
