Tool description on pop-up manualtoolchange
05 Jan 2021 23:09 #194174
by FedX
Tool description on pop-up manualtoolchange was created by FedX
does anybody added the description of the tool table to the prompt window of hal_manualtoolchange?
i can see that hal_manualtoolchange has a function do_change(n) where n is the toolnumber. Where does this function gets called, and is it possible to add the description written in the tool_table?
I use probe_basic, but it uses the same pop up like axis.
br
Dominik
br
Dominik
06 Jan 2021 23:53 #194307
by BigJohnT
Replied by BigJohnT on topic Tool description on pop-up manualtoolchange
07 Jan 2021 18:42 - 07 Jan 2021 21:35 #194389
by FedX
Replied by FedX on topic Tool description on pop-up manualtoolchange
In your hal config files i don't see a hal component for the toolchange, only some pins connected directly to qtpyvcp hal components. So i guess its possible to create a custom pop up window when using M6 directly in QtPyVCP? Is there a description how i can trigger a pop up message in QtPyVCP, haven't seen it so far..
OK i guess i have to have a look at the dialog section right? But in the documentation is only described how i trigger a pop up with a special button, how can i use a hal pin as trigger?
Last edit: 07 Jan 2021 21:35 by FedX.
07 Jan 2021 23:47 #194437
by BigJohnT
I don't use a popup for tool change just a label and a button. You can put anything you want in the label. It's in the upper right corner next to the press when changed button
raw.githubusercontent.com/jethornton/mil...mill-touch-v6-01.png
JT
JT
08 Jan 2021 01:36 #194453
by FedX
Ok now o understand your solution.
I would like to have the same tool change popup like gmocapy has. With tool number and description from tool table. Is there a way to use this instead of hal_manualtoolchange?
08 Jan 2021 15:30 #194502
Replied by andypugh on topic Tool description on pop-up manualtoolchange
hal_manualtoolchange only has access to the data that it gets from HAL, and that is just the tool number.
To display more information it would actually have to parse the tool table.
Which is, of course, do-able as it is a Python routine. I suspect that it doesn't because it's actually a rather old bit of code.
08 Jan 2021 19:15 #194527
by FedX
Yes is know that the hal components only accept hal pins and variables.
Is there any documentation how the manual toolchange is solved with gmocapy? Because that's exactly what I'm looking for for Qtpyvcp.
08 Jan 2021 19:25 #194528
Yes, but hal_manualtoolchange (or equivalent) is just a simple python program that happens to be a HAL component. There is nothing stopping it looking at the file system to find more tool data.
It could easily get everything _except_ the description from the Python interface: linuxcnc.org/docs/2.6/html/common/python...ding_linuxcnc_status
08 Jan 2021 21:01 #194544
by alkabal
Replied by alkabal on topic Tool description on pop-up manualtoolchange
The following user(s) said Thank You: FedX
18 Mar 2021 09:17 - 19 Apr 2021 14:38 #202718
by Stormholt
Replied by Stormholt on topic Tool description on pop-up manualtoolchange
A bit late to the party, but thought some of this might be useful to someone reading this thread.
I dont use the manual_toolchange, however have been greatly inspired in my solution. I run the code in an embed tab
Definitely not the best solution as it is alot of ctrl-c from the right places, but it gets the job done to my satisfaction
EDIT:
I dealt with consistency issues, turns out it was the frquency of my periodic method. can be fixed by either running more frequently like or as i have done by adding a the timedelay to my toolchange hal file
EDIT:
loadrt timedelay names=toolchange.timedelay
addf toolchange.timedelay servo-thread
setp toolchange.timedelay.on-delay 1.0
setp toolchange.timedelay.off-delay 0.1
net toolchange.tool-number <= iocontrol.0.tool-prep-number
net toolchange.tool-change-loopback <= iocontrol.0.tool-change
net toolchange.tool-change-loopback => iocontrol.0.tool-changed
net toolchange.tool-prepare-loopback <= iocontrol.0.tool-prepare
net toolchange.tool-prepare-loopback => toolchange.timedelay.in
net toolchange.tool-prepared-delay toolchange.timedelay.out => iocontrol.0.tool-prepared
Last edit: 19 Apr 2021 14:38 by Stormholt. Reason: Fixed bug
Time to create page: 0.093 seconds
