- User Interfaces
- AXIS
- M6 probing causes the display to put the extents at the bottom of Z probe depth
24 Feb 2021 00:42 - 24 Feb 2021 00:44 #199905
by turbostew
M6 probing causes the display to put the extents at the bottom of Z probe depth was created by turbostew
I have set up a remap of M6 for probing and I noticed that the extents lines on the toolpath display are set way down in Z. After much experimenting I realize it sets the extents at the bottom of the probe depth limits. I really want the extent display lines to be at g54 Z0 (datum point).
Ideas?
Thanks,
Kent
Ideas?
Thanks,
Kent
Last edit: 24 Feb 2021 00:44 by turbostew.
- Thank you received: 5944
24 Feb 2021 01:44 #199913
Replied by tommylight on topic M6 probing causes the display to put the extents at the bottom of Z probe depth
I am pretty sure i have read this same message earlier today, or ?
Sorry i can not help as i never used probe for mills, mainly use plasma machines.
24 Feb 2021 17:27 #200008
by turbostew
Replied by turbostew on topic M6 probing causes the display to put the extents at the bottom of Z probe depth
I am guessing maybe this problem is unique to me? Nobody else has encountered the Z- extents display at the bottom of the probe depth? My probe is lower than my table...
Kent
Kent
- User Interfaces
- AXIS
Time to create page: 0.065 seconds
