button to execute hal file
13 May 2021 17:16 #208742
by wasausky
button to execute hal file was created by wasausky
Hello everybody. I have a wireless joystick that uses the hal_input component.
the problem is that when disconnecting it the pins are lost and to use it again I have to execute the hal commands to reload the hal component.
I would like to implement a button to execute a file containing the hal command to use the joystick again.
i am using axis and linuxcnc 2.8 on raspberry pi 4.
13 May 2021 17:47 #208745
by Henk
Replied by Henk on topic button to execute hal file
You can probably use a custom user m code that issues a number of hal commands. Look at the m codes doc
There are ways to call this m code using a bitton
The following user(s) said Thank You: wasausky
13 May 2021 21:52 #208761
by wasausky
Replied by wasausky on topic button to execute hal file
Hello . Thank you, your answer served me. I already have the functional M code that configures the joystick for me now as I link it to a button
14 May 2021 04:04 #208779
by Henk
This is a bit old but still valid. Links a MDI command to a pyvcp panel button.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Adding_Custom_MDI_Buttons
14 May 2021 21:17 #208855
by wasausky
Thank you very much it works perfectly. I can now disconnect my joystick and connect it again with a button.
