how to use gmoccapy tool change pop up in axis
26 Jun 2021 14:55 #212963
by gerrg
Replied by gerrg on topic how to use gmoccapy tool change pop up in axis
I'm using linuxCNC 2.8.1, and I'm also using a mesa 7i76e, so I went through PncConf as well. I'll have to run through it again and check about the option for the manual toolchange prompt
Also, i haven't heard of qtvcp, but i'll look into that as well!
27 Jun 2021 01:36 #212991
Replied by cmorley on topic how to use gmoccapy tool change pop up in axis
i did get this to work in 2.8.
there is a 2.8.2 coming that gives this more options.
How did you get linuxcnc? is it compiled or is it from buildbot?
28 Jun 2021 16:25 #213157
by gerrg
I got it from the pre-compiled buster image, which has debian 10 and linuxCNC already baked into it.
29 Jun 2021 05:16 #213214
here is the files to try.
they should go in /usr/share/qtvcp/panels/tool_dialog/
then you need to change the line:
to:
loadusr -Wn tool_dialog qtvcp tool_dialog
Chris
to:
Chris
