Camera doesn't work in embeded tab
25 Jun 2021 12:27 - 25 Jun 2021 12:39 #212896
by BigDo
Camera doesn't work in embeded tab was created by BigDo
hello guys i'm trying to integrate my camera in an embeded tab but it doesn't work properly
i am on Axis 2.9.0 pre
linux kernel 4.19.0-16-rt-amd64
this is my configuration:
EMBED_TAB_NAME = Camera
EMBED_TAB_COMMAND = mpv /dev/video0 --wid {XID} --vf-add=drawbox=-1:2:-1:240:t=1 --vf-add=drawbox=2:-1:240:-1::t=1 --no-border
without parameter --wid {XID} it works fine but not embeded.
does someone know what is wrong with this --wid {XID} parameter?
Last edit: 25 Jun 2021 12:39 by BigDo.
28 Jun 2021 15:42 - 28 Jun 2021 15:47 #213153
I wonder if it is getting a valid XID in {XID}
Is your camera command in the POSTGUI file? It won't be able to embed it in Axis if Axis isn't loaded at the time.
Assuming that you are using code in the [DISPLAY] section then Axis should load it.
But, the docs seem to suggest -x {XID} not -wid {XID}. Where did you get -wid from? Presumably the mpv (what is that?) docs.
Replied by andypugh on topic Camera doesn't work in embeded tab
Last edit: 28 Jun 2021 15:47 by andypugh.
28 Jun 2021 15:56 #213154
I wonder where {XID} substitution occurs? And whether it is working properly.
Maybe try --wid={XID} and even --wid=3 (I doubt that _guessing_ a window ID is a good long-term solution)
Time to create page: 0.069 seconds
