Touch Off default value for offset
21 Sep 2021 16:54 - 21 Sep 2021 16:56 #221279
by wdcnc
Touch Off default value for offset was created by wdcnc
I have recently installed a laser pointer with an 'X' pattern on my Z axis. This pointer is offset from the router bit on the X axis by about 3" and from the Y axis by about 2". When I touch off on an axis, I have to manually enter these values to 4 decimal places (something like -2.9693). This works fine but I'd rather not enter these values each time I touch off on the X and Y axis.
Has anyone modified the axis.py script to allow for a default value to be specified in the .ini file so the offsets don't have to be typed in when touching off to the workpiece?
Thanks in advance.
Thanks in advance.
Last edit: 21 Sep 2021 16:56 by wdcnc. Reason: Added content.
- Thank you received: 5943
21 Sep 2021 18:12 #221284
Replied by tommylight on topic Touch Off default value for offset
What machine?
You can add a VCP button to do all that with just a click:
linuxcnc.org/docs/html/gui/gladevcp.html
21 Sep 2021 18:18 #221285
by wdcnc
Replied by wdcnc on topic Touch Off default value for offset
The machine is a homebuilt 3 axis gantry type.
Linuxcnc is 2.9 pre (and some long number) on Mint 19.3.
I'd really prefer not to have to give up screen real estate for a button.
21 Sep 2021 18:35 #221287
by wdcnc
Silly me, I didn't realize GladeVPC could run as a tab in axis. Looks like some piddling is in order. I need to get something working for a touchplate also so maybe I can integrate that.
24 Sep 2021 19:47 - 24 Sep 2021 19:49 #221517
Replied by rodw on topic Touch Off default value for offset
. doubled up.
Last edit: 24 Sep 2021 19:49 by rodw.
24 Sep 2021 19:48 #221518
This is how I moved to the XY laser position using a gmocappy macro. Should work for you.
Jog to where you want to set 0,0 by the laser and press a button. Easy
; Testfile go Laser position offset
; will jog the machine to a position to give
O<laser_off> sub
G21
G91
G0 X -40.685 Y -26.595
g10 l20 p0 x0 y0
O<laser_off> endsub
M2
26 Sep 2021 21:48 #221664
by wdcnc
I think that will work for what I need rodw. Thanks.
I was not having any luck with glade.
21 Oct 2021 17:09 #223827
by wdcnc
Just to follow up, with slight modification this works great for me from the MDI.
Thanks again.
Thanks again.
Time to create page: 0.095 seconds
