Hal_manualtoolchange did you know a way for popup allways on top
28 Sep 2021 21:28 - 28 Sep 2021 22:39 #221781
by alkabal
Hi
Did you know a way for ensure the popup for tool change and remove tool can keep above (allways on top, topmost) ?
I have try to edit the bin file and to add "app.wm_attributes("-topmost", True)" at different location without success.
Best regards
Best regards
Last edit: 28 Sep 2021 22:39 by alkabal.
29 Sep 2021 23:59 #221862
by cakeslob
Replied by cakeslob on topic Hal_manualtoolchange did you know a way for popup allways on top
I tried for a bit last night, no luck. its calling up a custom dialog widget, so I dont think wm.attributes will work here, but the whole window id thing is confusing to me still
github.com/LinuxCNC/linuxcnc/blob/master.../axis/tcl/dialog.tcl
maybe here
github.com/LinuxCNC/linuxcnc/blob/master.../tcl/dialog.tcl#L108
maybe here
The following user(s) said Thank You: alkabal
02 Oct 2021 23:14 #222059
by alkabal
Replied by alkabal on topic Hal_manualtoolchange did you know a way for popup allways on top
A lot of thanks that work like a charm with your suggestion !
Adding this line 220 :
wm attribute $w -topmost 1
github.com/LinuxCNC/linuxcnc/blob/8a18ca.../tcl/dialog.tcl#L220
But now mode difficult, is there a way for do the same things but using a command for set as full screen inside axisrc :
root_window.attributes('-fullscreen', True)
Another thanks !
Another thanks !
03 Oct 2021 21:52 #222148
by cakeslob
do you mean a button inside axis to make the toolchange dialog fullscreen? or do you mean make axis full screen?
03 Oct 2021 23:26 #222156
by alkabal
Oh sorry for unprecision.
My axis wndow is set as full screen using in .axisrc the option :
With this setting the patch "wm attribute $w -topmost 1" does not work.
I can get it work only using axis gui as regular windows.
Thanks for interest
Thanks for interest
03 Oct 2021 23:36 #222158
by cakeslob
try setting it manually
something like this
root_window.tk.call("wm","geometry",".","1024x768")
something like this
04 Oct 2021 01:28 - 04 Oct 2021 01:29 #222161
by phillc54
Replied by phillc54 on topic Hal_manualtoolchange did you know a way for popup allways on top
In the past I used the following in .axisrc to set the size of Axis, whether it is still valid I don't know.
maxgeo=root_window.tk.call("wm","maxsize",".")
fullsize=maxgeo.split(' ')[0] + 'x' + maxgeo.split(' ')[1]
root_window.tk.call("wm","geometry",".",fullsize)
Last edit: 04 Oct 2021 01:29 by phillc54.
04 Oct 2021 21:07 - 04 Oct 2021 21:09 #222219
by alkabal
Thanks for exemple but unfortunatly that does not do the same things.
You config allow window to be maximised.
What i like is window as full screen (task bar masked), i know how to do the screen config but i like to have popup allways on top (in this situation the working patch for popup topmost does not apply)
Br, thanks again
Br, thanks again
Last edit: 04 Oct 2021 21:09 by alkabal.
