Camera tab in Axis
21 Mar 2022 09:50 #237897
by Henk
HI
We are trying to implement camview embedded in Axis, but not having any success.
I followed the instruction here wiki.linuxcnc.org/cgi-bin/wiki.pl?Adding_Camview .
Repository added and update seemed to work.
LCNC starts, but the camview tab is blank.
Anyone done this lately?
Henk
Running 2.8.1 , Debian Stretch
Henk
- strahlensauger
- Thank you received: 64
21 Mar 2022 12:24 #237907
by strahlensauger
Replied by strahlensauger on topic camview
I just used mplayer. I had a lot of trouble getting camview to work.
Install mplayer
sudo apt install mplayer
and below the
[DISPLAY]
section add these lines
in the .ini file
EMBED_TAB_NAME = Camera
EMBED_TAB_COMMAND = mplayer -wid {XID} tv://0 -vf rectangle=-1:2:-1:240,rectangle=2:-1:320:-1
way easier than camview.
Worked in 2.7, 2.8 and 2.9 under buster and bullseye...
Install mplayer
and below the
[DISPLAY]
in the .ini file
- strahlensauger
21 Mar 2022 20:08 - 21 Mar 2022 20:15 #237952
by strahlensauger
Hm, never encountered that error. It ran out of the box....
try
sudo dmesg | tail
what does it tell you?
then, are there video devices ?
what does
ls /dev/
show?
After a restart, does
mplayer tv:// -tv driver=v4l2
show a window of the camera?
try
sudo dmesg | tail
what does
ls /dev/
show?
Last edit: 21 Mar 2022 20:15 by strahlensauger.
- robertspark
- Thank you received: 216
21 Mar 2022 21:33 #237960
by robertspark
Replied by robertspark on topic camview
i tried this on my setup and this is the response i got:
ive only just started to mess about with a camera, I have a pencil type supereyes usb microscope type camera for scanthing use
www.supereyes-store.com/collections/micr...er-health-kit-tripod
I installed cheese and i got an image
not to hack the OPs thread
rob@RobsCNC:~$ mplayer tv:// -tv driver=v4l2
MPlayer 1.4 (Debian), built with gcc-10 (C) 2000-2019 MPlayer Team
do_connect: could not connect to socket
connect: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing tv://.
TV file format detected.
Selected driver: v4l2
name: Video 4 Linux 2 input
author: Martin Olschewski <olschewski@zpr.uni-koeln.de>
comment: first try, more to come ;-)
v4l2: your device driver does not support VIDIOC_G_STD ioctl, VIDIOC_G_PARM was used instead.
Selected device: MICROSCOPE
Capabilities: video capture streaming
supported norms:
inputs: 0 = Camera 1;
Current input: 0
Current format: YUYV
v4l2: ioctl set format failed: Device or resource busy
v4l2: ioctl set mute failed: Invalid argument
v4l2: 0 frames successfully processed, 0 frames dropped.
Exiting... (End of file)
rob@RobsCNC:~$ ls /dev/
autofs log sg0 tty23 tty45 ttyS0 vcsa7
block loop-control shm tty24 tty46 ttyS1 vcsu
bsg mapper snapshot tty25 tty47 ttyS2 vcsu1
btrfs-control media0 snd tty26 tty48 ttyS3 vcsu2
bus mem stderr tty27 tty49 uhid vcsu3
char mqueue stdin tty28 tty5 uinput vcsu4
console net stdout tty29 tty50 urandom vcsu5
core null tty tty3 tty51 usb vcsu6
cpu_dma_latency nvram tty0 tty30 tty52 v4l vcsu7
cuse port tty1 tty31 tty53 vcs vfio
disk ppp tty10 tty32 tty54 vcs1 vga_arbiter
dri psaux tty11 tty33 tty55 vcs2 vhci
fb0 ptmx tty12 tty34 tty56 vcs3 vhost-net
fd ptp0 tty13 tty35 tty57 vcs4 vhost-vsock
full ptp1 tty14 tty36 tty58 vcs5 video0
fuse pts tty15 tty37 tty59 vcs6 video1
hidraw0 random tty16 tty38 tty6 vcs7 watchdog
hidraw1 rfkill tty17 tty39 tty60 vcsa watchdog0
hidraw3 rtc tty18 tty4 tty61 vcsa1 zero
hpet rtc0 tty19 tty40 tty62 vcsa2
hugepages sda tty2 tty41 tty63 vcsa3
initctl sda1 tty20 tty42 tty7 vcsa4
input sda2 tty21 tty43 tty8 vcsa5
kmsg sda3 tty22 tty44 tty9 vcsa6
rob@RobsCNC:~$
- strahlensauger
21 Mar 2022 21:50 #237962
by strahlensauger
Mine is a cheap China webcam with a 5m cable, but worked out of the box.
Strange that cheese worked with your cam and mplayer not, but
sometimes that happens
Maybe you can insert cheese in a tab in axis? But I don't know how to do
that...
that...
- robertspark
21 Mar 2022 21:56 #237963
by robertspark
i restarted and got this, i am going to try with cheese (ive had my camera a few years as the belief was that the high resolution cameras sometimes used video compression and were not good for part tracing / had a lower frame rate)
www.sheetcam.com/Scanything/index
ob@RobsCNC:~/scanything$ mplayer tv:// -tv driver=v4l2
Playing tv://.
supported norms:
Current input: 0
tv.c: norm_from_string(pal): Bogus norm parameter, setting default.
v4l2: ioctl enum norm failed: Inappropriate ioctl for device
Error: Cannot set norm!
Selected input hasn't got a tuner!
v4l2: ioctl query control failed: Invalid argument
libva info: VA-API version 1.10.0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_10
libva info: va_openDriver() returns 0
Opening video decoder: [raw] RAW Uncompressed Video
Movie-Aspect is undefined - no prescaling applied.
VO: [vdpau] 640x480 => 640x480 Packed YUY2
Selected video codec: [rawyuy2] vfm: raw (RAW YUY2)
Audio: no sound
Starting playback...
libvdpau-va-gl: VideoSurface::PutBitsYCbCr_glsl(): not implemented source YCbCr format 'VDP_YCBCR_FORMAT_YUYV'
[vdpau] Error when calling vdp_video_surface_put_bits_y_cb_cr: VDP_STATUS_INVALID_Y_CB_CR_FORMAT
MPlayer interrupted by signal 11 in module: filter_video
- MPlayer crashed by bad usage of CPU/FPU/RAM.
Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and
disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash.
[ This binary of MPlayer in Debian is currently compiled with
'--enable-debug'; the debugging symbols are in the package
'mplayer-dbgsym'.]
corrupted size vs. prev_size in fastbins
MPlayer interrupted by signal 6 in module: filter_video
- robertspark
21 Mar 2022 22:38 #237970
by robertspark
hmm this worked for me too...
github.com/wooksong/contributon2019-nns/issues/3
gst-launch-1.0 v4l2src name=cam_src ! videoconvert ! videoscale ! video/x-raw,format=RGB ! queue ! videoconvert ! ximagesink name=img_origin
21 Mar 2022 23:46 #237977
by cakeslob
unless camview is something else I dont understand,you just want to view a webcam right? it should be included as a qtvcp, ive been using it with an rpi and chinese borescope cam, theres an axis sample config
github.com/LinuxCNC/linuxcnc/blob/master.../qtvcp/qtvcp_tab.ini
EMBED_TAB_NAME= qtscreen
EMBED_TAB_COMMAND= halcmd loadusr -Wn qtvcp_embed qtvcp -d -c qtvcp_embed -x {XID} cam_align
