Axis 2.9.0~pre: jogging moves the tool cone, but not the steppers
14 Sep 2022 20:13 #251932
Replied by PCW on topic Axis 2.9.0~pre: jogging moves the tool cone, but not the steppers
I don't think its a LinuxCNC build issue or many more people
would be affected. As I said before I would more suspect
dropped packets which may be a hardware/network driver/OS issue
Here is the complete log of 7I96S setup packets captured
with tcpdump. You should get the same results (other than the host name)
Note that everything up to line 911 is setup, that is, the periodic:
host --> 7I96S Read Request
7i96S --> host Read Data
host --> 7I96S Write data
triplets start at line 911
14 Sep 2022 21:47 #251938
by Dr. John
Replied by Dr. John on topic Axis 2.9.0~pre: jogging moves the tool cone, but not the steppers
You've yet to explain why it works with pncconf and not with axis. I don't think you can. In principle, both send/receive information with the 7i96s card via the same mechanism, i.e., via halcmd. In the case of pncconf, everything works as expected. This suggests that your hypothesis about the problem being hard/network driver/OS can't be right. In the axis case, nothing is getting out to the 7i96s card. That's because halcmd isn't receiving anything to send. That's been proven with the evidence that I've put here.
However, just for grins and giggles, let me try to the tcpdump approach. Unfortunately, I've never used it, nor can I decode what the packets mean. So, would you please give me some more details about how I should use it and how I might interpret the packets?
Thanks.
Thanks.
14 Sep 2022 22:26 #251944
If there is a communication issue it may be sensitive to timing or packet size
and this is completely different between pncconf and LinucCNC
immediate following error if you command a move.
What I am suggesting is that during initial parsing of the hal file and sending this
setup information to the 7I96S something has gone wrong, which may in fact be
dropped packets, a symptom of a hardware/OS or Ethernet driver issue
The fact that I can run LinuxCNC 2.9 on a 7I96S successfully with your hal file
suggest this is not LinuxCNC related but rather something very specific about
your setup (which points to hardware or network/OS issues)
The tcpdump command is
sudo tcpdump -i [your Etherent device] -x dump.txt
(lauch this before you start linuxCNC and immediately exit linuxCNC once it starts)
Not true, the periodic data writes and reads must be working or you would get anIn the axis case, nothing is getting out to the 7i96s card. That's because halcmd isn't receiving anything to send
14 Sep 2022 22:30 #251947
Sorry, the correct tcpdump command is:
sudo tcpdump -i [your Etherent device] -x > dump.txt
14 Sep 2022 22:47 #251948
by Dr. John
Nevermind. I think I figured it out myself.Attached are a couple of tcpdumps, one for pncconf, the other for axis. Tell me what you think. There is no evidence in either case that the network link is failing.
Well, I tried to attach a zip file, but it's too big. They will be too big when I split them as well. Please give me some direction about the best way to get them to you. The unzipped sizes are 66MB and 43MB for pncconf and axis respectively.
Maybe the best approach is to edit out something, but I'm clueless as to what. Would the binary version of these files work for you?
14 Sep 2022 22:54 #251949
You should edit the files down to about 1000 lines each
nothing interesting happens beyond that
15 Sep 2022 17:44 #252014
by Dr. John
OK, attached are the trimmed tcpdump files. Let me know what you find.
Meanwhile, it is my understanding that the handling of the packets communicated between the computer and the I/O card are handled by halcmd (or some lower level software), not by axis as such. Is this not so?
15 Sep 2022 18:03 #252017
by arvidb
Replied by arvidb on topic Axis 2.9.0~pre: jogging moves the tool cone, but not the steppers
I'm not entirely sure, but I think the python-based GUIs use the "linuxcnc" python module to communicate with the core LinuxCNC components. Source in
src/emc/usr_intf/axis/extensions/emcmodule.cc
15 Sep 2022 18:04 #252018
by arvidb
Also, there were no files attached to your latest post.
15 Sep 2022 19:44 #252036
by Dr. John
I'm not sure what happened, but it may be that the files had an extension of .log which doesn't seem to be on the list of acceptable types. So, now they are attached as a .zip file.
Time to create page: 0.195 seconds
