VCP launches in gladevcp, but errors from linuxcnc
31 Jan 2023 03:25 #263289
by JetForMe
VCP launches in gladevcp, but errors from linuxcnc was created by JetForMe
Debian 12 testing with latest updates.
I'm able to launch my VCP via gladevcp well enough, but when I include it in linuxcnc, I get this error:
If I launch my panel in gladevcp, it runs, and I don't get the two errors, and it displays my UI:
I'm at a point where I need to start integrating with Axis, so I'd love to get past this.
(gladevcp:213239): Gtk-WARNING **: 19:09:22.058: GtkPlug only works under X11
<commandline>:0: gladevcp exited without becoming ready
$ linuxcnc axis.ini
LINUXCNC - 2.10.0~pre0
Machine configuration directory is '/home/rmann/camsync-vcp'
Machine configuration file is 'axis.ini'
Starting LinuxCNC...
emc/iotask/ioControl.cc 786: can't load tool table.
Note: Using POSIX non-realtime
Found file(lib): /home/rmann/linuxcnc/lib/hallib/core_sim.hal
Found file(lib): /home/rmann/linuxcnc/lib/hallib/sim_spindle_encoder.hal
Found file(lib): /home/rmann/linuxcnc/lib/hallib/axis_manualtoolchange.hal
Found file(lib): /home/rmann/linuxcnc/lib/hallib/simulated_home.hal
Found file(lib): /home/rmann/linuxcnc/lib/hallib/check_xyz_constraints.hal
note: MAXV max: 5.000 units/sec 300.000 units/min
note: LJOG max: 5.000 units/sec 300.000 units/min
note: LJOG default: 0.250 units/sec 15.000 units/min
note: jog_order='XYZ'
note: jog_invert=set()
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
[GladeVCP][INFO] Logging to: /home/rmann/gladevcp.log (logger.py:107)
[GladeVCP.QTVCP.QT_ISTAT][WARNING] Embeded tab configuration -invalid number of TAB_NAMES vs TAB_LOCATION - guessing default. (qt_istat.py:421)
Version: 3.11.1 (main, Dec 31 2022, 10:23:59) [GCC 12.2.0]
Embeded tab command "halcmd loadusr -Wn camsync gladevcp -c camsync -u ./camsyncvcp.py -x 12583336 ./camsync.ui" exited with error: 1
task: 1017 cycles, min=0.000002, max=0.007927, avg=0.001155, 0 latency excursions (> 10x expected cycle time of 0.001000s)
LinuxCNC terminated with an error. You can find more information in the log:
/home/rmann/linuxcnc_debug.txt
and
/home/rmann/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
$ gladevcp -c camsync -H camsync.hal -u camsyncvcp.py camsync.ui
tool_mmap_user(): tool mmap not available
poll(): continuing without tool mmap data
31 Jan 2023 03:46 #263292
by JetForMe
Replied by JetForMe on topic VCP launches in gladevcp, but errors from linuxcnc
Ah! I found a workaround, if not a solution:
export GDK_BACKEND=x11
31 Jan 2023 07:57 #263310
Replied by rodw on topic VCP launches in gladevcp, but errors from linuxcnc
Progress!
This is all part of your wayland/opengl issue
Using XFCE take away a lot of pain as I said before.
Time to create page: 0.060 seconds
