Enabling coolant controls
08 Feb 2023 15:23 #264057
by HiSH
Enabling coolant controls was created by HiSH
What is necessary to activate the coolant controls in axis?
- Thank you received: 5935
08 Feb 2023 16:54 #264063
Replied by tommylight on topic Enabling coolant controls
net coolant-on to whatever pin controlls the coolant pump.
There is also
net coolant-mist
Do check those, on the phone so that is from memory.
There is also
net coolant-mist
09 Feb 2023 08:16 #264112
by HiSH
Replied by HiSH on topic Enabling coolant controls
Thank you. May be, i did something wrong.
In my hal-file i connect
net coolant-on gladevcp..hal_tstbtn hm2_[HOSTMOD2](BOARD).0.7i77.0.0.putput-05
and
net coolant-mist gladevcp..hal_tstbtn2 hm2_[HOSTMOD2](BOARD).0.7i77.0.0.putput-04
The pins are working correct, but no checkbox appears on the tab.
and
09 Feb 2023 09:03 #264119
Replied by rodw on topic Enabling coolant controls
I can't quite remember the details but axis needs to sense you have a spindle on your machine via hal somewhere. SOmebody might remember the details..
09 Feb 2023 11:23 #264128
Probably halui...
On the phone so not much help, but make a new test configuration with the wizard, chose the coolant pins, save, then open both hal files from the test config and your working config, use the search function to find any mention of coolant and check the deferences.
09 Feb 2023 13:44 #264134
by HiSH
Ok, thank you, this helps!
In the hal-file there should be exactly:
net coolant-mist <= iocontrol.0.coolant-mist
and
net cooland-flood <= iocontrol.0.coolant-flood
(Of course, "<=" isn't necessary.)
and
Time to create page: 0.134 seconds
