Does AXIS display STOCK/BLOCK? (Can it be made to?)
10 Mar 2023 15:50 #266295
by clunc
Does AXIS display STOCK/BLOCK? (Can it be made to?) was created by clunc
I never noticed before that my implementation of AXIS does not appear to show the outline of the stock material which is available in the (STOCK/BLOCK ...) line.
Can it do that?
This is the first time my stock has been of a different size from the project, and I'd like to see confirmation of the alignment of the model with the stock. (I guess I could be staring right at it and not recognize it.)
Thank you.
Can it do that?
Thank you.
11 Mar 2023 23:42 #266444
Replied by andypugh on topic Does AXIS display STOCK/BLOCK? (Can it be made to?)
Not as a built-in feature. But NativeCAM used a fairly clever scheme to show the srock, by drawing it with G0 moves that were inside optional delete blocks.
12 Mar 2023 01:43 #266456
Replied by cmorley on topic Does AXIS display STOCK/BLOCK? (Can it be made to?)
What program is creating a STOCK/BLOCK line?
short answer - no.
That is not code linuxcnc recognizes.
Someone would need to code this in the libraries. (Qtvcp has some hooks for it)
short answer - no.
Time to create page: 0.090 seconds
