Axis "Override Limits" checkbox gone?
07 May 2023 17:33 #270873
by HansU
Axis "Override Limits" checkbox gone? was created by HansU
I remember that there has been this checkbox to override the limit switches, but all configurations I run, they don't have that checkbox.
It's still somewhere in the code, but I wonder if this only shows under special circumstances?
It's still documented and I had to search a bit to find an image with this.
Does anyone know how to get this checkbox enabled?
09 May 2023 00:24 #270973
by cakeslob
Replied by cakeslob on topic Axis "Override Limits" checkbox gone?
try the "l" key on keyboard, when your on the limits,
it also says you need to have them configured as limit switch
they are still being created and removed
github.com/LinuxCNC/linuxcnc/blob/master...cripts/axis.py#L4189
here was the only thing I can find removing it
10 May 2023 17:56 #271118
by HansU
Replied by HansU on topic Axis "Override Limits" checkbox gone?
Great, thanks for that hint. It's only displayed when the limit switch pin is connected to another pin. Interesting. I should add that to the documentation...
Time to create page: 0.123 seconds
