Machine Limits not showing in Linuxcnc 2.8.4
15 May 2023 18:08 #271411
by kajukcnc
Machine Limits not showing in Linuxcnc 2.8.4 was created by kajukcnc
I'm in the process switching from 2.7.x to 2.8.4 and encounered a weird issue. In the Preview window machine limits (Show Machine Limits) are not shown unless I toggle off 'Show Program' and 'Show Program Rapids'. Behaviour is the same in both Debian 10 Live booted from a USB and if I do a full installtion. I tested it on two PCs (one with dedicated Radeon card and one with built-in video) and the result is the same.
When booting back into 2.7.x the machine limits are properly shown regardles of other 'Show ...' toggles state.
Any ideas?
Thank you!
Dmitri
Any ideas?
Thank you!
Dmitri
17 May 2023 12:01 - 17 May 2023 12:02 #271535
by kajukcnc
Replied by kajukcnc on topic Machine Limits not showing in Linuxcnc 2.8.4
I googled a lot to see if anyone reported the same issue and could not find anything. Seems like I'm the only one with this issue.
Last edit: 17 May 2023 12:02 by kajukcnc.
18 May 2023 05:23 #271592
Replied by cmorley on topic Machine Limits not showing in Linuxcnc 2.8.4
I have this/similar problem on one test system using Mint.
I'll have to see if your 'work around' is the same.
- Bas Cilyco
10 Oct 2023 12:57 #282683
by Bas Cilyco
Replied by Bas Cilyco on topic Machine Limits not showing in Linuxcnc 2.8.4
I have the same problem with Linuxcnc 2.8.4 not showing the machine limits. I have also installed a Raspberry Pi and the problem does not exist there. No solution found, so I reinstalled Linuxcnc 2.7.14.
10 Oct 2023 18:48 #282695
In 2.9 there was a change to address this problem.we changed the dotted lines to solid lines and tgatcseemed to work.
Maybe we need to back port it.
05 Jan 2024 20:42 #289899
by kajukcnc
Upgraded to 2.9.2 and machine limits are back. Thank you!
Time to create page: 0.063 seconds
