User Interfaces
AXIS
NGCGUI panel
NGCGUI panel
Thank you received: 0
26 Aug 2023 11:06 #279006
by Sansey
I use linuxcnc with AXIS graphics
I'm asking for help with setting up the macro panel. I created several tabs with macros using NGCGUI technology, but the problem is that if the number of lines with parameters exceeds 10, then the 11th line is created in the second column .. which is not visible due to the button bar and the spindle.
how to make all parameters fit in one column. ?
User Interfaces
AXIS
NGCGUI panel
Time to create page: 0.080 seconds
