Easy overview TAB
21 Nov 2023 08:56 - 21 Nov 2023 09:00 #286147
by OpenDev
Easy overview TAB was created by OpenDev
Hello,
after I didn't find anything suitable.
I wanted to ask if there is a way to put an html/pdf/image into a tab of Axis, whether via the ini or the .axisrc/py file.
The whole thing should show an operating instructions/schematic illustration.
Could someone help me with this? Thank you
Last edit: 21 Nov 2023 09:00 by OpenDev.
21 Nov 2023 14:09 #286168
by MaHa
Replied by MaHa on topic Easy overview TAB
I have done that, by using the lathe macro project as base.
forum.linuxcnc.org/41-guis/26550-lathe-macros
Only need to modify the lathehandler.py and glade .ui file as desired, and create your own .svg file, following the requirements.
The following user(s) said Thank You: OpenDev
21 Nov 2023 14:28 #286175
by OpenDev
Replied by OpenDev on topic Easy overview TAB
wow that looks good, it even looks like it could be made inactive. Thank you very much for the information.
