auto-reload on run NC files
18 Apr 2024 19:29 #298570 by paco0314
When I run a NC file it is reloaded automatically. Every time. Even [resume on given line] is selected. (The [R] button isn't needed any more.) Can I prevent it from doing so?
(I use a python GUI to generate the NC code. I dont want fill in all parameters very time I start the run.)
LinuxCNC/AXIS Version 2.9.1
THX.
20 Apr 2024 10:28 #298712 by andypugh
Are you saying that you have a Python FILTER routine that is being called every time you press "Run"?
Otherwise, I am unclear what is causing the Python code to run.
20 Apr 2024 16:03 #298738 by paco0314
Yes, a python filter. But dosn't matter. The problem is with ordinnary nc-files as well.
  1. Load a nc-file (plain gc-text).
  2. Edit the file.
  3. Run program - you'll run the modification.
20 Apr 2024 17:01 #298740 by andypugh
21 Apr 2024 06:41 #298762 by paco0314
Well, thank you allot. Both deal exacly with my problem. But I got dizzy and lost by reading. What is the conclusion? No easy fix?
When was this 'feature' introduced first, in other words: which older version should I use instead?
What next? Guess I should switch over to on of these toppics.
