MDI history
05 Jan 2011 12:05 #6425
by Rick G
MDI history was created by Rick G
On one of my computers I have both a lathe and a mill setup with EMC.
I have separate folders for each and can launch to either machine with no problem. This has worked well for me.
I did notice however that the MDI history is not unique to each machine but in fact is the same.
Where is the MDI history stored? Can we name what file to store the history to keep it separate for each machine?
Rick G
Rick G
05 Jan 2011 13:07 #6432
by BigJohnT
Replied by BigJohnT on topic Re:MDI history
Rick,
I did find that it is in your home directory in a hidden file .axis_mdi_history.
I don't see or know of any way to pick a different file for different configs.
06 Jan 2011 11:54 #6472
by Rick G
Replied by Rick G on topic Re:MDI history
The old hidden file routine, that's the second time this week I fell for that.
Thanks for the info John.
It would be nice if the file was located in the current machine folder to avoid the problem.
I wonder how many people use more than one configuration on a computer.
Rick
Rick
06 Jan 2011 14:46 #6475
Replied by andypugh on topic Re:MDI history
Rick G wrote:
I do.
From discussion on the IRC channel last night we might well see that fie moving in the next release.
I do.
06 Jan 2011 14:59 - 06 Jan 2011 15:00 #6476
by BigJohnT
Did someone make some progress on that? I know jepler made a quick stab at it and it broke the ini read...
I know it has confused me in the past as I usually have several different configs on on computer at one time.
Last edit: 06 Jan 2011 15:00 by BigJohnT.
07 Jan 2011 13:17 - 07 Jan 2011 13:18 #6509
by BigJohnT
Rick,
psha will make an update to master will allow the MDI history to be local to your configuration directory. I tested it this morning.
Last edit: 07 Jan 2011 13:18 by BigJohnT.
07 Jan 2011 13:31 #6510
by Rick G
Great.
I look forward to using it, it will make life easier.
Rick G
Rick G
26 Apr 2020 16:09 #165673
by JohnnyCNC
Did this ever make it into a release? I'm running 2.8.0Pre1 and the MDI history still shares .axis_mdi_history.
I looked in the 2.8 docs and didn't see anywhere that mentions it.
J
Replied by JohnnyCNC on topic Re:MDI history
Rick,
J
05 May 2020 03:44 #166725
by KCJ
Replied by KCJ on topic Re:MDI history
No, MDI history is still stored in ~/.axis_mdi_history
The following user(s) said Thank You: JohnnyCNC
09 May 2020 20:44 - 09 May 2020 20:44 #167173
by KCJ
Hello John,
On further investigation it is possible to change the MDI history location, at least for axis.
It is an INI option.
[DISPLAY]
MDI_HISTORY_FILE = PATH
Last edit: 09 May 2020 20:44 by KCJ.
Time to create page: 0.131 seconds
