Extended pyvcp_widgets
12 Feb 2014 20:48 - 24 Feb 2014 18:10 #43802
by ArcEye
Extended pyvcp_widgets was created by ArcEye
Hi
I have now updated my extended pyvcp_widgets.py file to reflect recent changes to the bar widget and the checkbox, amoungst others.
I have also included a sample config to demo multilabel and bar changing and show other widgets being set to default values
If you want to download the whole file rather than make ad hoc edits it is available from
www.mgware.co.uk/LinuxCNC/extended-pyvcp.html
Read the py file header for each widget to see the xml syntax required to address the various extra pins etc
They are backwardly compatible with the original widgets, ie. are all additions which if not used, do nothing
Most are outlined and demonstrated in this section across various posts too.
I have undoubtedly cocked up something updating this, if you find any bugs let me know
Last edit: 24 Feb 2014 18:10 by ArcEye.
The following user(s) said Thank You: BigJohnT
14 Feb 2014 12:50 #43845
Replied by cmorley on topic Extended pyvcp_widgets
is this an improved version of the patch you offered for inclusion some long time ago?
Chris M
Chris M
14 Feb 2014 15:27 #43849
by ArcEye
Replied by ArcEye on topic Extended pyvcp_widgets
Hi Chris
Basically yes
Just updated with a couple more things, the remote toggling of check boxes by hal pin and ability to have coloured bar which changes colour to reflect the value it is representing ( OK, Warn, Danger type scenario)
Saves them being scattered all over different forum posts
Basically yes
14 Feb 2014 17:41 #43851
I should just add them to master...I am busy with other stuff for a while but will try to remember to look into this again.
Chris M
Chris M
14 Feb 2014 18:17 #43852
by ArcEye
If there is some danger of them going somewhere, I will clean up the file (lots of comments so I could find things or remember what I did)
and maybe amend a copy of the existing html doc page to reflect the changes.
I'm trying to get to grips with some CAD/CAM stuff at the minute, I will re-post when done
17 Feb 2014 00:12 - 24 Feb 2014 17:37 #43902
by ArcEye
Hi Chris
The cleaned up py file is here
(removed pending edit)
Perhaps JT can assist re the html file, for some reason the auto TOC generator creates 2 lists, I can't see an immediate reason, probably some arcane formatting error
Last edit: 24 Feb 2014 17:37 by ArcEye.
The following user(s) said Thank You: Rick G
17 Feb 2014 17:17 #43910
by Rick G
Replied by Rick G on topic Extended pyvcp_widgets
Hello ArcEye,
Great addition. Nice timing too as we are in the process of setting up a plasma table with torch height control using Mesa's THCAD, J.T.'s THC component and spinboxs with initial values set from NGCGUI subs and then modified.
The resulting values are stores in the var file so they can be restores when the machine is restarted. Just did a quick test and works great.
Because the original spinbox did not have a hal parameter pin we set the voltage with a sum2 component, the value stored in the file or from the sub added to a spinbox with an initial value of 0.
We did a slight edit to connect a value to the new parameter pin.
In the xml...
Where M105 is..
M105 P99 Q13
Works as expected.
I do need to edit the M105 as...
M105 P99
Creates a invalid hal argument and will set the spinbox to -1
Thanks for the additions.
Rick G
In the xml...
<spinbox>
<width>"5"</width>
<halpin>"volts-adjustment"</halpin>
<param_pin>1</param_pin>
<min_>-100</min_>
<max_>100</max_>
<resolution>1</resolution>
<font>("Helvetica",10)</font>
<format>"1.0f"</format>
<font>("Arial",10)</font>
<initval>0</initval>
</spinbox>
Where M105 is..
#!/bin/bash
#m105 to set thc values
#voltage is P
#adjust is Q
voltage=$1
vadjust=$2
halcmd setp sum2.0.in1 $voltage
halcmd setp pyvcp.spinbox.1.param_pin $vadjust
#halcmd setp thc.feedrate $feedrate
exit 0
M105 P99 Q13
Works as expected.
M105 P99
Rick G
17 Feb 2014 19:11 #43913
by ArcEye
Hi Rick
You're welcome, I'm glad someone is using them. I think Mariusl who originally requested the spinbox mod was doing something quite similar to your THC set up
I seem to remember being bitten by that in the past myself, if you don't specifically set P or Q you end up with -1, to 6 decimal places.
The fact that it passes a float value even if you enter an integer also caused problems, where the value was a selection from a menu, because bash would not match say 3 with 3.000000
This bash script shows the conversion I had to do when using a logging script M121 P1(to start) or P2(to end)
.. and yes it was a hacked version of axis-remote
M105 P99
#!/bin/bash
if [ ! $# -ge 1 ]; then
echo "Usage: M121 n - where n is 1 (start 2 (end "
exit 1
fi
float=$1
int=${float/\.*}
case $int in
1 ) axis-remote --get
echo "JOB FILE NAME" >> /tmp/joblog.txt
echo "*************" >> /tmp/joblog.txt
cat /tmp/filename.txt >> /tmp/joblog.txt
echo "Started at:-" >> /tmp/joblog.txt
date >> /tmp/joblog.txt;;
2 ) echo "Ended at:-" >> /tmp/joblog.txt
esac
exit 0
18 Feb 2014 13:57 #43936
Does this patch change the current behavior of widgets in a major way?
18 Feb 2014 15:50 #43937
by ArcEye
Hi Chris,
It is not a patch, it is a full replacement, I can create a patch against a fresh clone of master if you want it in that format.
No, it should be backwardly compatible.
The new fields require to be set before anything happens.
For instance the bar widget retains the default color setting for the bar and only if all three range fields are completed with valid colours, will it colour the bar based upon the value at the halpin.
There is one new pin in the checkbox widget that is created automatically, but that does not affect anything unless it is used.
Time to create page: 0.151 seconds
