MONSTER - A learning experience... pyVCP machine
- Askjerry
- Thank you received: 31
03 Sep 2016 18:49 - 03 Sep 2016 18:50 #79985
by Askjerry
Replied by Askjerry on topic MONSTER - A learning experience... pyVCP machine
andypugh said...
Yes and no... I understand the parallel port completely as I have been using it for years. I'll get the machine operational and figure out the resolution, maximum speed, acceleration, and other factors. Then, once I have all those configurations saved, I can install and play with a MESA card... something I have never done before.
Better to take one unknown step with five known steps to look for errors than to dive into a totally unknown situation and hope for the best.
I just now pulled the first motor off... the great news is that it has a 2:1 tooth belt in there so I'll double my power and resolution with a lower microstep setting. The bad-ish news is that the plate does not fit the current motor... I'll have to machine a new plate. But... this is a perfect job for the new Frankenlab CNC that I am working on.
Shameless plug and playlist here!
Stay tuned... hoping to get this first motor installed today. (maybe??)
In the context of the money you are talking of spending, using the parallel port seems like s false economy.
Last edit: 03 Sep 2016 18:50 by Askjerry.
The following user(s) said Thank You: liwenbinbit
- liwenbinbit
29 Sep 2016 02:31 #81069
by liwenbinbit
Replied by liwenbinbit on topic MONSTER - A learning experience... pyVCP machine
Hi, Jerry
How was your INTRO_GRAPHIC working? Is it showing up every time you start the MONSTER ?
Wenbin
Wenbin
- Askjerry
29 Sep 2016 05:22 #81071
by Askjerry
It replaces the stock image and works exactly as the original image does. I have the time set to 4 or 5 seconds.
You can configure it however you like... Or set it to none if you prefer.
- liwenbinbit
29 Sep 2016 05:33 #81072
by liwenbinbit
Interesting! Mine doesn't work, it shows nothing. I followed exactly what you have configured for this intro_graphic .
What version are you using ? I am on
LinuxCNC 2.7.7 .
Thanks for your reply and sharing, Jerry.
LinuxCNC 2.7.7 .
- Askjerry
29 Sep 2016 05:54 #81073
by Askjerry
If it shows nothing... it is because LinuxCNC cannot find the file, or the file is in the wrong format.
In the monster.ini file there is a line that defines the graphic...
INTRO_GRAPHIC = ./IMAGES/splash.gif
This starts with the directory or folder that the image is stored in... the dot-slash indicates going from the current location into one level of directories... in this case IMAGES/ folder. Inside of that folder... the actual graphic file splash.gif must reside.
You must create a sub-directory inside your configuration folder called IMAGES. Then place the graphic inside that sub-folder.
Once you do that... it should work fine... providing you updated the line in the ini file to match.
If you are still stuck... ZIP the whole CONFIG folder and email it to me... I'll take a look and configure it for you.
My Email is: jerryarutherford(at)gmail(dot)com Obviously I replaced the "@" and "." so i don't get hit by spambots.
- liwenbinbit
29 Sep 2016 06:15 #81074
by liwenbinbit
Thanks, Jerry.
I just made it ! The reason is my previous image is NOT REAL .gif, it was a .jpeg file and I renamed it as .gif.
It can be opened by other software but it seems that LinuxCNC doesn't read this "fake" gif well.
- Askjerry
29 Sep 2016 06:45 #81075
by Askjerry
No. A gif and a jpg have different compression routines... and Linux (or any operating software) would fail to properly open it because it was using the wrong method.
I find that LinuxCNC seems to "like" the GIF and PNG format better than others. I use INKSCAPE to create my graphics, then export them to PNG. I find the images look better, have more colors, and the transparency works well.
Jerry
Jerry
- liwenbinbit
30 Sep 2016 16:53 #81113
by liwenbinbit
Thank you, Jerry !
