PYVCP - SCALE Widget - Set Initial value
16 Aug 2015 13:25 - 16 Aug 2015 13:31 #61425
by Askjerry
PYVCP - SCALE Widget - Set Initial value was created by Askjerry
I've created some really nice panels now... I usually include a SCALE widget to control the jog feed rate.
Typically this scale will go from 1 to 60... depending on the machine... and as such, will initially come up as 1. I always forget that... and click a jog button... then wonder why the machine "didn't move"... but it did... just VERY slowly. So I wanted it to start up faster than that.... a different initial value.
Here is the typical code I use...
I wanted it to start off initially as 15 instead of 1... so I looked at the SPINBOX widget which hasSo I decided to give it a try... the PYVCP document didn't say anything about it... but I figured it would probably work.
It works!
(Just wanted to pass that info along to someone else who might need it.)
Here is the code I used if you want to tinker with it...
Jerry
I added a new section to my web page for CNC stuff if you are interested... ASKJERRY.INFO
<vbox>
<relief>RAISED</relief>
<bd>2</bd>
<label>
<text>"Jog Speed"</text>
<font>("Helvetica",10)</font>
</label>
<scale>
<halpin>"jog-speed"</halpin>
<orient>HORIZONTAL</orient>
<resolution>1</resolution>
<min_>1</min_>
<max_>60</max_>
</scale>
</vbox>
<initval>15</initval>
It works!
<vbox>
<bd>2</bd>
<label>
</label>
<scale>
<min_>1</min_>
<max_>60</max_>
</scale>
</vbox>
Jerry
Last edit: 16 Aug 2015 13:31 by Askjerry. Reason: Clarity / Add Link
16 Aug 2015 19:00 #61431
by BigJohnT
Replied by BigJohnT on topic PYVCP - SCALE Widget - Set Initial value
I looked in the manual and initval is indeed in the scale description.
JT
JT
The following user(s) said Thank You: Askjerry
16 Aug 2015 20:35 #61440
by Askjerry
Replied by Askjerry on topic PYVCP - SCALE Widget - Set Initial value
I just looked again... you are right... I must have missed it.
(2:00am programming caught up with me I guess.)
Thanks,
Jerry
Shall I delete this post?
Thanks,
Jerry
16 Aug 2015 22:02 #61442
by BigJohnT
That's up to you, if you edit the original post to just explain what you did it would be informative to others that search the forum.
JT
JT
16 Aug 2015 22:25 #61447
by Askjerry
I'll leave it... you are correct... it could help another coffee deprived programmer...
Time to create page: 0.119 seconds
